Old 01-17-2014, 09:02 PM   #1
EightiesOnly
EightiesOnly's Avatar
LS swap temp sending unit not working
Alright, so I recently finished my 5.3 swap in my '86. I'm using a custom temp sender adapter and the temp sender doesn't work properly. It just reads about 100* unless I put it in park and let it idle, then it rises to about 195-200. Once I start driving, it gradually goes all the way back down.
I removed the plug on the passenger side and put the adapter there.
I thought maybe the coolant flow is just below the sender while driving, but it's full of coolant and others on here have used adapters in this spot just fine.
Any suggestions?
LC.
My Truck Build (1986 LS powered c10)
EightiesOnly is offline   Reply With Quote
Old 01-17-2014, 09:09 PM   #2
truckdude239
truckdude239's Avatar
Re: LS swap temp sending unit not working
Ive found that most coolant sesnors need the coolant flowing across the end of the sensor to work properly
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 01-17-2014, 09:20 PM   #3
EightiesOnly
So perhaps the coolant is flowing across the end while idling in park better than while driving?
The better thing to do would have been to drill and tap the plug whole, but it's too late for that now.
LC.
Old 01-18-2014, 09:33 AM   #4
Andy4639
Old member
Andy4639's Avatar
Wink Re: LS swap temp sending unit not working
You can get away with a shallow adapter but I think yours is to deep. Yes at idle the coolant isn't moving as fast through the system and it hits the sendor longer. But once you start driving the coolant is moving so fast and not getting to cover the whole area of the sender. My 2 cents worth anyway.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-18-2014, 11:20 AM   #5
Hart_Rod
Hart_Rod's Avatar
Try to find an adapter that will get the temp sensor closer to the head. Dakota digital sells some I think.
http://www.dakotadigital.com/index.c...rod/prd111.htm
Hart_Rod is offline   Reply With Quote
Old 01-18-2014, 01:40 PM   #6
EightiesOnly
I think I'll look into these Dakota Digitals. Does it not matter if the sender and gauge match?
LC.
Old 01-18-2014, 05:33 PM   #7
Andy4639
Old member
Andy4639's Avatar
Most gauges are matched to the sender. But you should be able to get one that works for a certain temp.
