01-18-2014, 11:21 AM | #1 |
Michigan metal works control arms
You guys got anything to say about these control arms good ,bad or indifferent. I was thinking about getting some to go with my dropmember. As they are a bit different looking
01-18-2014, 12:45 PM | #2 |
Re: Michigan metal works control arms
Had to look them up. My personal concern would be that they use a jeebus joints instead of traditional ball joints, since im not familiar with that setup I would have to do some research.
01-18-2014, 12:48 PM | #3 |
Any pictures..I've never heard of them before.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
01-18-2014, 12:53 PM | #4 |
67-72 parts collector,…
They have been around for quite a while.
They make arms for stuff no one else makes. They can build flat plate arms, tube arms, with Jeebus joints or stock balljoints. They even custom make spindles. Do some research. Quality stuff here.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 01-18-2014 at 02:30 PM. |
01-18-2014, 01:22 PM | #5 |
http://michiganmetalworks.com/ here is the link for them. they look like a good product and i have talked with the owner a couple times nice guy and very helpful. they make a budget set for the dropmember and a higher $$ set that is about same price as Nates arms.
01-18-2014, 10:31 PM | #6 |
The plate arms look heavy. That's the only concern I'd have.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
01-19-2014, 11:07 AM | #7 |
I think their "Dodger" upper control arms are slick. That's a great concept for anyone with a Z'd chassis or a raised crossmember, because if you go up more than 2", your steering shaft WILL hit the upper control arm. For what you're getting, the price ($199) is a smokin' deal.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
02-13-2019, 06:34 PM | #8 |
I just stumbled onto this post. Does any one have any good or bad updated feedback on these guys yet?? Looking to do a 1.5" or 2" sectioned factory crossmember, coilovers and 2.5" drop drop spindles. How are their drop spindles?
