01-18-2014, 01:13 PM | #1 |
New battery..... dead?
Hey all,
A few days before I went home for Christmas, the battery in my green 1970 C20 died, so I replaced it. Then about three days later I parked it at my uncle's farm for a month while I went back home. When I came back to Kansas it started right up. I didn't have any problems, until yesterday. When I started it yesterday afternoon I noticed it took a little longer than usual to start, but didn't think too much of it. Then when I was leaving the auto parts store it really took a bit to crank it over. When I got back, I shut it off and tried to restart it. It cranked very slowly for about three to four revs and then just clicked. It did that every time I tried for about 10 min. afterwards. I gave up and called it a day. Sorry for the long post, anyone got any ideas? I really need to get this fixed because I'm trying to sell the truck. Thanks.
White70C20 1970 Blue C20 - 250, 4 speed 1985 Ford Thunderbird 2005 Pontiac G6 |
01-18-2014, 01:20 PM | #2 | |
Re: New battery..... dead?
JohnG |
01-18-2014, 01:28 PM | #3 |
That could be. Unfortunately I don't have a DVM.
01-18-2014, 01:37 PM | #4 |
I'd buy or borrow a voltmeter. You should be getting in the neighborhood of 14 volts when the truck is running.
Even a cheap Harbor Freight multimeter can be very useful for working on your truck and lots of other things. You could also pull your alternator and take it to have it tested for free at almost any auto parts store. |
01-18-2014, 02:15 PM | #5 |
i'd take the battery cables off clean them up real good and where they mount put some dielectric grease on them and reinstall them
01-18-2014, 03:12 PM | #6 |
It's also probably worthwhile to have the battery checked to make sure you didn't get a lemon.
Willie Swamp Angel Truckers '72 C10 Highlander People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. |
01-18-2014, 03:51 PM | #7 |
Msgt USAF Ret
If you have not converted to an internally regulated alternator you should suspect the external regulator as well.
Here is the diagram of the system. Check the brown wire on the regulator at terminal 4 for 12 volts with the key on. Check the red wire at the regulator on terminal 3 with the key on or off for 12 volts. Check for 12 volts at the white wire on the alternator plug with the key on. Check for 12 volts at the blue wire on the alternator plug with the key on or off. Check for a good ground between the external regulator and the radiator support. Check for a good ground between the regulator and the alternator.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
01-19-2014, 12:49 PM | #8 |
I had the same problem with charging after I replaced my alternator. It was a wire connector that was worn from being bent to many times. Check all wiring and connectors for good contact and no frayed wires.
01-25-2014, 04:11 AM | #9 |
Hi all,
I'm still having the battery draining issue. I took the battery and alternator in to have them tested - both are good. So, that leads me to my question: what are some of the things that could be draining the battery? I've had this truck since October 2012 and it was fine up until last Saturday. I did install a set of LED taillight bulbs in the truck a couple days before the battery died last week. It required a new flasher relay which was included in the kit. I was also working on replacing the steering wheel and the horn kept sticking so I disconnected the wires running to what I assumed to be the horn relay. After putting the old steering wheel back on, I connected the wires again. I was wondering if maybe one of these two things could've caused a drain on the battery. I'm not sure why they would, but it's worth a try. If any of you have any more suggestions please let me know. I'm trying to decide whether or not to sell this truck, and if I can't find the source of the problem that in itself might be enough to persuade me to sell it. Thanks!
01-25-2014, 08:02 AM | #10 |
i had a simular issue . turned out to mbe voltage regulator .
This is MY rifle.There are many others like it but this one is MINE. Beware the man who only owns 1 rifle , he probably knows how to use it. |
01-25-2014, 09:55 AM | #11 | |
If there is current flowing then you need to inspect/retrace your wiring mods to isolate the cause of the current drain. good luck! JohnG |
01-25-2014, 11:24 AM | #12 |
Rusty Nuts
Here is a quick way to find out if you have something drawing off your battery. With a charged battery and key switch off along with any other accessories, disconnect the ground and then touch the ground cable to the ground post and if you see some minor sparks you have current going somwhere. Now the problem is finding out from what. Now that you said you worked with your lights and horn that is the first two places to start.
now if you have a radio or clock with constant power to them for memory you will see sparks also. But the bigger the spark the bigger the draw is.
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 |
