Old 01-18-2014, 01:43 PM   #1
53chevy.pu
53chevy.pu's Avatar
53 Chevy pickup build and swap ideas
I'm going to share photos and ideas on my build of 53 chevy pickup.
Here the day I bought it Dec 24, 1979 for $75.00 from a farmer in Pine River Minnesota when I was living there. Did not run the trans was laying on the floor. i coulnt wait till spring. I was 17 years old.
53chevy.pu is offline   Reply With Quote
Old 01-29-2014, 10:51 PM   #2
53chevy.pu
53chevy.pu's Avatar
Re: 53 Chevy pickup build and swap ideas
Here Is the brake setup I made for the pickup. The brackets I made, the parts used are: the booster from 2001 S-10 blazer, Master cylinder 2000 Chevy 1500 pickup. mounted behind the transmission cross member mount. I'm using the stock transmission mounting cross member. I cut a notch out and welded a piece of metal to close in the gap. the rod ends are 3/8" with a 3/4" DOM steel tube 1/8" wall thickness. Also using the stock Brake pedal and bracket.
Old 01-29-2014, 11:00 PM   #3
53chevy.pu
53chevy.pu's Avatar
Here are more photos of the brake master cylinder setup
Old 01-29-2014, 11:16 PM   #4
53chevy.pu
53chevy.pu's Avatar
Stock trans cross member photos
Old 08-10-2014, 09:48 PM   #5
53chevy.pu
53chevy.pu's Avatar
I've seen from another member on installing Bear Claw latches (53lochevy) I used his idea and start building mine for my pickup. Here are some photos of mine. still have to finish up welding but I am going to install the window track and window and make sure there are no issues. This is for reference use only.
Photo 1 is the built latch brackets
photo 2 marking the bracket for cutting.
photo 3 the finished cut
photo 4 cutting the door
photo 5 test fitting the latch before tack welding.
Old 08-10-2014, 09:58 PM   #6
53chevy.pu
53chevy.pu's Avatar
more photos
Old 08-10-2014, 10:08 PM   #7
53chevy.pu
53chevy.pu's Avatar
more photos 2
Old 08-10-2014, 10:12 PM   #8
53chevy.pu
53chevy.pu's Avatar
photo set 3
Old 08-10-2014, 10:27 PM   #9
53chevy.pu
53chevy.pu's Avatar
photo set 4
Old 08-10-2014, 10:34 PM   #10
53chevy.pu
53chevy.pu's Avatar
Photo set 5
Old 08-10-2014, 10:37 PM   #11
53chevy.pu
53chevy.pu's Avatar
Still have to finish welding, I will post more photos.
Old 08-10-2014, 10:50 PM   #12
Rednek13x
Rednek13x's Avatar
looking good! i might some day do the bear claw install when i get tired of my doors flying open randomly while going down the road.
Rednek13x is offline   Reply With Quote
Old 08-10-2014, 11:00 PM   #13
53chevy.pu
53chevy.pu's Avatar
When I do the drivers side I will shoot a youtube video on the install.
Old 08-11-2014, 01:03 AM   #14
solidaxel
solidaxel's Avatar
Thanks for the pics and info on the Bear Claws
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 08-19-2014, 07:10 PM   #15
53chevy.pu
53chevy.pu's Avatar
Photo of my pickup right now. ready to clean up the wiring and add the GM TBI.
53chevy.pu build
