Old 01-18-2014, 09:08 PM   #1
heathbirkendahl
350 with 700r4 - What stall should I use?
I think I have a 1800 in there now.
1971 C/10 - Orange & White
2009 GMC 1500 - Lowered 3/4 22' KMC Slides
heathbirkendahl is offline   Reply With Quote
Old 01-18-2014, 11:05 PM   #2
cdowns
cdowns's Avatar
Re: 350 with 700r4 - What stall should I use?
leave stock stall speed tranny calls for unless you have a hiperformance engine
Old 01-18-2014, 11:10 PM   #3
Longhorn 70
Longhorn 70's Avatar
Agreed! If you haven't done so already, look at the converter lockup posts and kits.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 01-18-2014, 11:13 PM   #4
heathbirkendahl
I have a Bowtie Overdrives tranny with lock up.
Old 01-20-2014, 11:41 AM   #5
heathbirkendahl
Whats everyone else running?
Old 01-20-2014, 12:30 PM   #6
1972SUPERSB
1972SUPERSB's Avatar
I had a 350 ZZ4 crate engine with a 2400 stall with the 700R4. I liked it a lot. If that helps any
Jeff
1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt
1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior
1972SUPERSB is offline   Reply With Quote
Old 01-20-2014, 01:02 PM   #7
heathbirkendahl
That's a big help. I have a ZZ4 as well.
Thank you,
Heath
Old 01-20-2014, 01:06 PM   #8
1972SUPERSB
Thank you,
Heath
Where did u get ur tranny from?
Jeff
Old 01-20-2014, 07:24 PM   #9
hugger6933
5500 +150. no, just kidding I did have one that loose once but that was a lot of horsepower ago. 22-2400rpm you know the stall act diff based on your motor and its cam and the compression your making[or in some instances bleeding off with the cam]. But Generally a 2200 to 2400 is gonna be the best for everything you can throw at the truck that is driven a lot. You really don't want your cruise rpm much lower than your stall it will heat things as fast as a transbrake.good luck with witch ever one you choose and I hope it works well for you, If your buying a custom one ask if you can send it back to have it loosened up or tightened up if needed that is pretty important. Jim
hugger6933 is offline   Reply With Quote
Old 01-20-2014, 10:18 PM   #10
WIDESIDE72
WIDESIDE72's Avatar
I wouldnt go much above 2400 advertised stall. It will be dependent on your engine, etc where it actually stalls. Be ready to drop some coin compared to th350/ 400 converters.
WIDESIDE72 is offline   Reply With Quote
Old 01-21-2014, 12:04 AM   #11
Z10
Z10's Avatar
I'm doing this same swap now. I'm also running a ZZ4 with a GM rebuilt 700r4 out of a 91 Corvette which has a 2200 rpm stall.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 01-21-2014, 12:58 AM   #12
70blackfish
corvette stall.....
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 01-21-2014, 01:52 PM   #13
heathbirkendahl
Originally Posted by z10 View Post
i'm doing this same swap now. I'm also running a zz4 with a gm rebuilt 700r4 out of a 91 corvette which has a 2200 rpm stall.
nice!
Old 01-25-2014, 01:08 AM   #14
heathbirkendahl
Sounds like my 1800 is to low. Thanks guys.
Old 01-26-2014, 11:44 AM   #15
brad_man_72
the boat guy
brad_man_72's Avatar
Cam, compression, weight, gears, tires, intended use. All important factors when choosing a stall.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 01-26-2014, 12:09 PM   #16
67ChevyRedneck
67ChevyRedneck's Avatar
I've been researching this as well, and I can't seem to find a good straight answer.
BTO sells 1600, 1800, and 2200 rpm stalls under their "standard stall" converters. Which one would pair up well with a +/-250 horse 350/700R/3.73? I was thinking the 1800? It's a daily driver/cruiser.
Truck only spins around 1500rpm @ 50mph in OD... should I go with the 1600 then???
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 01-26-2014, 01:24 PM   #17
heathbirkendahl
I spoke with a tranny pro on 700r4's. Said the 1800 is fine if the truck has a mild cam. My truck idles fine. I'll let you know how it goes.
Old 01-26-2014, 02:47 PM   #18
Tinkermc
In my72 GMC I have a 350/700r4 with 2400 stahl and works like new money.
Tinkermc is offline   Reply With Quote
