Old 07-19-2003, 07:56 PM   #1
stateamind
And you call that a what?
stateamind's Avatar
307 & 3speed trans
This came out of my 71 parts truck. It supposedly ran strong when the truck was parked because of the PO getting t-boned, rendering the truck undrivable. Sat for several years before I bought the truck for parts. It does turn over. but I never tried to start it. Inside is clean, no gunk or buildup under the valve covers. Complete minus valve covers, p/s pump and alt. I need those for one of my projects. I'll say $200, come pick it up. I don't have any overhead on this, so if that's too high, just make me an offer. I need to get this out of the garage to make room for more junk. Located abt 30 miles west of Nashville.
I also have the column and all the linkages, including clutch/brake pedal setup if interested in those to go with it.
stateamind is offline   Reply With Quote
Old 07-20-2003, 07:03 PM   #2
stateamind
stateamind's Avatar
ttt
Old 07-22-2003, 01:49 AM   #3
stateamind
stateamind's Avatar
one more time then off to Ebay ...
Old 07-22-2003, 09:32 AM   #4
CPNE
Resident Curmudgeon
CPNE's Avatar
I'd be interested in the following, if real cheap
1. Clutch rod from pedal to z-bar
2. z-bar
3. Engine z-bar ball stud with bracket and bolts
4. Frame z-bar bracket
5. Z-bar to clutch fork rod and hardware
6. Tranny shift rods (complete with compression nuts at top and brackets that bolt to tranny at bottom).
7. Frame x-member for bell housing
8. Flywheel (maybe)
Basically all the parts for a small-block 3-speed setup
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
