Old 01-18-2014, 04:26 PM   #1
Stevie G
mcgaughy's spindles and steering bind
Hey there gang,
I just spent a couple hours sifting through threads on suspension drops, steering, and Mcgaughy's, but can't find anyone with the same issue. I purchased a set of Mcgaughy's drop spindles and six lug discs for my 69 C10.
Everything seemed to be going fine until I went to put the tie rods and center-link together. For some reason they decided to maintain the outer tie rod position relative to the stub axle instead of the lower ball joint. This totally screws up the steering geometry. major bump steer issues, and the inner tie rods now hit the idler arm and pitman arm whenever I try to turn. Has anyone else run into this?
Stevie G is offline   Reply With Quote
Old 01-18-2014, 04:34 PM   #2
midniteblues
midniteblues's Avatar
Re: mcgaughy's spindles and steering bind
did you have the drag link out? it sounds like you have it in backwards the inner tie rods should be behind the center link the nuts are out front. this is a easy mistake too make because it will still fit. ask me how i know
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 01-18-2014, 06:32 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
x2
Keith
Convert to disc brakes.
Old 01-18-2014, 06:32 PM   #4
lolife99
lolife99's Avatar
Originally Posted by Stevie G View Post
Hey there gang,
Got any pics?
Keith
