wiring issues
Believe I have looked around but im at a standstill on my rewire. I ordered a ez wire 21 circuit harness. Person before me had already ripped out sections of the wiring so it was hard to just pull and replace. Here are a few things im having trouble with. A diagram of the wiring coming out of the steering column would be awesome. On the igntion do I just need to splice into the old wiring that on the clip because my kit definitely doesnt have the clip that fits if so what splices to what. Ill stop here and see what responses I get and go from there. Sorrt if this is up somewhere else I just couldnt seem to locate it. Heres some pictures
Re: wiring issues
Might start with the basic vehicle wiring scematics in the factory service manual. They can be found in section 12.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Re: wiring issues
The connectors you have in your hand in photos 2 and 3 look like ignition switch connectors for a later model with lock steering..
If you think you can... Or think you can`t.. You are right. |
![]() Join Date: Apr 2010
Re: wiring issues
I don't know if this will help you.
The Older Generation
Re: wiring issues
Or you could check this out: http://67-72chevytrucks.com/vboard/s...d.php?t=185856 Be sure and skim through the whole thread if you have time. A lot of individual components are discussed in the other posts. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 01-19-2014 at 10:58 AM. |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Re: wiring issues
Check this thread for your key switch
http://67-72chevytrucks.com/vboard/s...d.php?t=469854 Here's one for the column connector http://67-72chevytrucks.com/vboard/s....php?p=6106983 ........ Refer to the diagram in post 4 for wire colors.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Re: wiring issues
So for the ign I should clip the wires and splice in? I think ill do the same for the colum as well
Re: wiring issues
Where can I get like a key if you will that tells what 20dbl, 18dbl etc means for all the wires
#9 | |
Re: wiring issues
Just take a very small flat blade screwdriver & insert it into the plug to push down on the little tab that holds it into the connector.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
#10 | |
Msgt USAF Ret
Re: wiring issues
20 dbl=20 gage dark blue, 16brn = 16 gage brown etc. Here is a wiring diagram with more examples. Wire gages are in many charts in inch sizes as well as metric.
Re: wiring issues
Thanks for all the help! Much appreciated! Plan to have it running this weekend!
Re: wiring issues
Heres a few issues im having. Please explain the green and brown wires coming off the ignition and what are all the wires coming off the headlight switch assembly. Also in the 3rd why is the acc wire so small compared to the kit? Thanks in advance
#13 |
Msgt USAF Ret
Re: wiring issues
First off I have to chastise you for not mentioning what year truck you have.
The green and brown wires off the ignition switch are for the temperature and brake warning lights in the idiot light dash. They are run to the ignition switch so that when the ignition switch is turned to the start position it grounds these two wires and turns on the lights to check the bulbs.. There should be two wires connected to the ACC on the ignition switch. One is the 12 gauge Accessory brown wire that goes to the fuse panel, and the smaller one is the brown/white stripe wire that goes to the inside of the bulkhead connector. It is a resistor wire for the alternator exciter wire, that comes out the other side of the bulkhead connector as a 16 gauge brown wire, that goes to the no. 4 terminal on the external voltage regulator. The regulator connects it to the alternator when the ignition key is turned on, by the white wire on the no. 2 terminal on the regulator. You should have these wires on the headlight switch. Red wire for power to the headlights. Light blue wire for power from the red wire to the dimmer switch. Orange wire for power to the brown wires to the tail lights . Green wire for power to the fuse panel to power the gray dash light wires. White wire for a ground wire to the dome light. The arrows show the two, brown and brown/white wires. At the bottom is the headlight switch. This diagram shows the fuse panel and the green wire that comes from the head light switch. Also the 12 gauge brown ACC wire and over to the left is the bulkhead connector with the resistance wire ( brown with white stripe ) connected with the brown wire from the idiot light if you have one.
#14 |
Re: wiring issues
Its a 72 c10 swb. I am upgrading to a new fuse box and the people before me ruined the wiring im getting confused trying to pull and replace. Thanks for the help ill work on it more asap. Try to get this all figured out
#15 |
Re: wiring issues
Anyone on here near OKC out of curiosity incase im still stumped?
Tags |
wiring issue |
