Old 01-19-2014, 01:34 PM   #1
gigolo258
1963 grille surround question
I would like to know the year breakdown on 60 to 66 grille surrounds,I have a 63 and have heard that the earlier versions have a slightly narrower spacing on the notches on the bottom,Thanks
gigolo258 is offline   Reply With Quote
Old 01-19-2014, 02:01 PM   #2
60-66
60-66's Avatar
Re: 1963 grille surround question
It has to do with the different frames, 1960-1962 and 1963-1966 is the breakdown of years for the frames and grille surround.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 01-19-2014, 04:27 PM   #3
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Interesting, According to the parts book
60-61 3757465
62 3796300
63 3826778
60-66 675034 with a note stating:
Note 1. When using on 1960 thru 1963 models it is necessary to relocate two holes on each side.
Old 01-19-2014, 05:17 PM   #4
60-66
60-66's Avatar
Yes that is interesting. Check the parts history books on those numbers and you will see starting from the top, were changed to the next number and in the end they used the true 63-66 surround on all of them 1960-1966. They will fit but that's not how they came new.
Heres a few examples that show the differences. This first one is a 1962 with the shallow notch, these frames are one inch wider at this point and have a narrow rail under the notch in the surround,
This next one is a 1965
and heres the front of a 1963, same as 64 65 66.
Old 01-19-2014, 06:26 PM   #5
aerotruk63
aerotruk63's Avatar
I hope you understand I'm not debating the issue, I have not been exposed to a grill surrounds from each year, but are the number and location of the holes for mounting the different year grills 60-62 and 63 - 66 similar?. I had read that the 63 grill mounts with 4 screws while the 64-66 mounts with 3. Does a 64 or 65 or 66 original grill surround have 4 holes or 3? I had read from an aftermarket supplier that there were 3 different models. 60-62, 63 by itself then 64-66.
Old 01-19-2014, 06:46 PM   #6
60-66
60-66's Avatar
Yes, I understood Norm, I just had to look up each of those numbers. Love these parts challenges as it makes me think. Now you have another good point. One I need to look at. I have a nice true 1960 Surround I need to dig out. There's also a different one with a bracket and a rubber bumper that is I think Suburban only.
Old 01-19-2014, 07:18 PM   #7
aerotruk63
aerotruk63's Avatar
The 1963 Preliminary Parts Book I carry in the truck lists
3817716 C/K 10 EXC PANELS
3826778 C/K 10-20-30 PANELS
From a 64 Burb
Old 01-20-2014, 01:34 AM   #8
BLK65K10
There are differences in the original grilles surrounds for the different grilles. The 60-61 have a different mounting hole pattern and didn't require a recess for the plug in to the headlight bulb. When they switched to the single large headlight they had to provide a recess for the plug in to live. The 62 and 63 grilles I believe have a similar bolt pattern. The 64-66 have only a 3 bolt pattern that is quite different from the previous years. The 64-66 also has the deepest recess for the plug in. The 60-66 gmc grille will bolt into the 60-61 chevy grille surround but original 64-66 gmcs have the large recess for the plug in though it is not used and a chevy grille will not bolt in without redrilling new mounting holes. These are my observations from disassembling over 30 pickups. Hope this helps.
BLK65K10 is offline   Reply With Quote
Old 01-20-2014, 01:47 AM   #9
BLK65K10
Here is a photo of a 60-61. Notice it is flat underneath of where the headights would be. I will post a photo of a 64-66 tomorrow.
Old 01-20-2014, 07:10 AM   #10
aerotruk63
aerotruk63's Avatar
Great contribution BLK65K10. On this site it just takes some experienced guy to clarify.
Old 01-20-2014, 10:28 AM   #11
jbgroby
jbgroby's Avatar
Welll the 60 GMC was different not sure IF this was the same for all years.
jbgroby is offline   Reply With Quote
Old 01-20-2014, 01:32 PM   #12
60-66
60-66's Avatar
From a 64 Burb
Heres what I mean by the Suburban and Panel truck extra bracket on the grille surround, it gets a rubber pad that sits on the bumper bracket. This one on the truck doesn't have the bumper bracket on at the moment.
Old 01-20-2014, 01:37 PM   #13
60-66
60-66's Avatar
Heres 3 different 63-66 grille surrounds all with different factory holes punched. The 3 hole one is the same as a 1966 I compared to. The 4 hole one is like Aero said and I agree could be a 1963. The other one has 6 holes and my only guess is its supposed to fit all grilles.
Old 01-20-2014, 08:49 PM   #14
gigolo258
Thanks for the interest in this research,I will know what to look for now for my 1963.It is C10 Custom panel and I will probably have to add the special bracket to my replacement grille surround when I get one but will use my original as a donor.thanks for your help and OEM forever,Adam
Old 01-20-2014, 09:37 PM   #15
aerotruk63
aerotruk63's Avatar
Does your panel have the rubber frame mounts as well as the rubber on that additional bracket?
Old 01-20-2014, 10:38 PM   #16
A.T. RockDriller
A.T. RockDriller's Avatar
I think those two parts would work together as an upgrade.
Les Hunter
'59 3803 someday to be 3853
'63 GMC K1000...351E, TH400 Daily
'66 GMC 4000...351C, 5&2
A.T. RockDriller is offline   Reply With Quote
Old 01-20-2014, 11:44 PM   #17
BLK65K10
It looks like 60-66 got everything covered so my photos would just be redundant. I use to have one that had a shallow indent in it but I must have sold it as I couldn't find it.
Old 01-21-2014, 12:09 AM   #18
60-66
60-66's Avatar
Yes the Panel trucks were the same as the Suburban brackets both frame and grille surround from 1963-1966.
Old 01-21-2014, 12:11 AM   #19
60-66
60-66's Avatar
I was hoping you could help confirm some of what we are talking about. Always nice to have more input from the group and to see what differences are out there.
Old 01-21-2014, 12:30 AM   #20
Grandpa54
Grandpa54's Avatar
the 1963 preliminary parts book i carry in the truck lists
3817716 c/k 10 exc panels
3826778 c/k 10-20-30 panels
from a 64 burb
my 65 panel has these mounts for the radiator support, does anyone know if someone remakes them ?
Grandpa54 is offline   Reply With Quote
Old 01-21-2014, 12:38 AM   #21
BLK65K10
My 65 and 66 suburbans I had also had the bracket with rubber bumper on it that sits on the bumper brace.
Old 01-21-2014, 12:49 PM   #22
60-66
60-66's Avatar
Heres a Suburban one on EBAY that you just need to add one hole for 1963
http://www.ebay.com/itm/1964-66-chev...ef2109&vxp=mtr
Old 01-21-2014, 08:10 PM   #23
gigolo258
60-66 thanks for the Ebay piece and all the pics and info but I have an Arizona grille surround coming this spring and wanted to be able to do a visual comparison on these parts,Thanks you aero truk also ,the members on this forum are extremely helpful and this is not the end of my quest for knowledge.
Old 01-21-2014, 08:34 PM   #24
aerotruk63
aerotruk63's Avatar
It's subjects like this, that I'd like to go through, part by part, to compare for everyone to know the differences. You don't have to be a purist to appreciate the differences.
Old 01-21-2014, 08:49 PM   #25
60-66
60-66's Avatar
I totally agree, posting pictures and seeing actual differences with other knowledgeable input is very helpful . Keeping these trucks OEM is for me, boy that sounds familiar ?
