Old 01-19-2014, 04:08 PM   #1
bowhunter65
wtb 4x4 wheel bearing spindle
wtb 4x4 wheel bearing spindle 1971. I can buy a new hub and bearings, but nobody makes the spindle. I would be interested in The spindle hub and bearings. or just the spindle.
bowhunter65 is offline   Reply With Quote
Old 01-19-2014, 07:26 PM   #2
w314speed
Re: wtb 4x4 wheel bearing spindle
Is it for a K10 or K20? Thanks, Dan
w314speed is offline   Reply With Quote
Old 01-19-2014, 09:39 PM   #3
bowhunter65
It's a k10. thank you dan for clarifying that
Old 01-19-2014, 09:45 PM   #4
bowhunter65
Old 01-20-2014, 12:03 AM   #5
JimH2828
In 71 small bearing spindles were used. Around the mid 70s large bearing spindles came out as they held up better. I believe both work in the same hub. Do some research on Spicer 706570X.
-Jim
JimH2828 is offline   Reply With Quote
Old 01-20-2014, 09:15 AM   #6
CUSTOM/10
CUSTOM/10's Avatar
You can also use the spindle 7 hub assembly from a 73+ ( Corp. 10 bolt )
But you to replace it as an assembly, spindle, bearing & hub because the bearing are a little larger.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
