Old 01-19-2014, 04:35 PM   #1
66fleetsidewarrior
Need help on brakes!!!!
So I've never done drum brakes like these before and the manual I have isn't really helping. Is there anything I need to do to get the drum off to access the shoes? I'm having a really hard time getting it off, as in it won't move at all. I've sprayed it down with some WD-40 and beat it with a hammer and it will not budge. NEED SOME HELP HERE!!!
66fleetsidewarrior is offline   Reply With Quote
Old 01-19-2014, 04:43 PM   #2
jhrusk
Re: Need help on brakes!!!!
May have to put a little heat on it or continue to soak with wd-40,the drum is probably rusted to the hub.
check out SANFORD build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=522019
jhrusk is offline   Reply With Quote
Old 01-19-2014, 05:02 PM   #3
66fleetsidewarrior
I'll try that. Different people have told me that I need to take off the axle nut, loosen the adjustor key or just keep whacking with a hammer. I'll take some heat to it and hopefully that will get it to come off. Thanks for the info!
Old 01-19-2014, 05:15 PM   #4
mikie 1954
You don't say whet truck you have,but if it like mine, a 3/4 ton GMC, there are screws in the front that you have to take out?
mikie 1954 is offline   Reply With Quote
Old 01-19-2014, 05:18 PM   #5
66fleetsidewarrior
Sorry, I guess that info would be helpful. I have a six lug '66 fleetside c10 2wd
Old 01-19-2014, 05:27 PM   #6
chakah
chakah's Avatar
try loosening on the adjustment, that should help
"El Jerry"
'03 3500 Duramax dually
'96 1500 ext. cab Chevy
'66 swb C-10
'63 Panel
'60 VW vert
'56 VW vert
chakah is offline   Reply With Quote
Old 01-19-2014, 05:37 PM   #7
Rich 5150 69
Rich 5150 69's Avatar
If they are front drums ( original ) they will be riveted to the hub, you will have to grind the rivets off or remove hub/drum together...
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 01-19-2014, 06:35 PM   #8
66fleetsidewarrior
they are the front, they are what looks like the original. They do have rivets, or at least i'm pretty sure that's what those are. What is the advantage of taking them off together instead of grinding off the rivet.
Old 01-19-2014, 06:44 PM   #9
jhrusk
if you grind the rivets off you can remove the drum without removing the hub.
Old 01-19-2014, 07:19 PM   #10
66fleetsidewarrior
When I go to put them back on what will secure them if the rivet is no longer there?
Old 01-19-2014, 07:24 PM   #11
Sharps40
The wheel and the lug nuts secure it.
Back off your shoes.
Remove the spindle nut and front bearing.
Pull off the hub and drum assembly.
Rebuild your brakes.
Put it all back together riveted or put it all back together with the hub separate from the drum so yer not always havin to break into yer bearings to do brake work.
Sharps40 is offline   Reply With Quote
Old 01-19-2014, 07:29 PM   #12
66fleetsidewarrior
Thanks for the advice guys!
Old 01-19-2014, 09:18 PM   #13
tincan1966
tincan1966's Avatar
I'd go ahead and pull the hubs. If this is a project you've just started and do not know the history, it wouldn't hurt to clean and repack the bearings and install new grease seals as maintenance.
tincan1966 is offline   Reply With Quote
Old 01-20-2014, 03:18 AM   #14
MusicMan70
MusicMan70's Avatar
Here's a useful link.
http://www.pbase.com/nufsed/drumbrake
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
