01-19-2014, 07:44 PM | #1 |
Factory underbed fuel tank?
01-19-2014, 07:49 PM | #2 |
Re: Factory underbed fuel tank?
I believe that is a dealer add on
1968 chevy lwb, getting ready to join forces with the 70 gmc 1970 gmc swb, getting ready to be a 68 chevy swb 1971 gmc lwb 2500 2wd Sierra Grande 1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins |
01-19-2014, 07:55 PM | #3 |
huh thats first time ive seen one
01-19-2014, 10:44 PM | #4 |
It's aftermarket or dealer installed. It's not factory.
01-20-2014, 12:18 AM | #5 |
My 69 has a tank that looks very similar. It was installed at a RV shop shortly after the original owner purchased the truck.
01-20-2014, 12:24 AM | #6 |
Carpe manana
Looks an awful lot like the 72-only GM installed tank...here's a truck so outfitted http://67-72chevytrucks.com/vboard/s...d.php?t=363854 as is my K20 linked in my signature below
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
01-20-2014, 01:28 AM | #7 |
Old member
That's like 5 gallon tank! Man it looks very small in the picture may not be but it looks like it to me!
01-20-2014, 09:02 AM | #8 |
Going by the filler neck,it appears to be a '72-only auxiliary tank. Off the top of my head,I believe they are 8 gallon(?),maybe more like 10
01-20-2014, 02:18 PM | #9 |
The picture is just close-up skewed.
That appears to be the factory RPO NL2 aux. tank, 19 gallon capacity. Optional on 72 CK20 and C30 fleetside pickups The spacers appear to be the metal bed version. It is missing all the undercab plumbing, selector valve, wiring and gauge selector switch. At least from the pictures provided. Adding pictures so this thread has some value after the CL ad goes away.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
01-20-2014, 05:09 PM | #10 | ||
"I ain't nobody, dork."
My 1972 GMC has the holes in the bed and on the upper front fleetside on both side of the truck from Aux tanks. The holes for the selector switch are still in the floor right below the drivers side of the seat. One of the PO's removed them.
Look at the front of the bedside just behind the stock filler neck in this pic. You'll see the hole where the aux filler neck should come through. There is an identical one on the other side. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
01-20-2014, 06:51 PM | #11 |
Gary, Your truck probably had a pair of in-bed tanks. Most of the aftermarket saddle tanks used side doors (including the GM accessory saddle tanks) or wheel well fillers. The really high through bed fillers are usually only seen with in-bed tanks. But the GM NL2 and earlier N18 aux tanks did use a similar left side only with a vent pipe style filler.
01-20-2014, 07:48 PM | #12 |
here is a couple pics of mine there is a sheet metal cover inside the bed for the filler tube that I dont have a pic of
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
01-20-2014, 07:56 PM | #13 |
That's the same tank my '72 Camper Special had factory installed. Wish I was closer, mine was full of dirt, rust, was rusted through.
Take Care Troy |
01-20-2014, 11:42 PM | #14 |
Well, I'll be a monkey's uncle. I didn't think the factory installed them.
I guess I learned something new. |
01-21-2014, 12:55 AM | #15 |
There was a '72 Sierra Grande in my area with the factory aux. tank. The high mounted filler is a giveaway, there is a metal shroud over the filler pipe in the bed as 67swb72klb states.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
01-21-2014, 01:04 AM | #16 | |
Mine had the factory option tank and it also has the filler in the same location, there's a sheet metal cover in the bed that hides the tube going through the bed and up to the filler hole.
Take Care Troy |
01-21-2014, 10:49 AM | #17 |
Well,I remembered wring again. Could be the funky scrunched pictured threw me off. I'new they were almost something...10 or 20
Factory:
01-21-2014, 11:56 AM | #18 | |||
I can snap some pics of them later on today for you to check out if you'd like. Gary
