New Engine Idles Rough
I took out my 307 and put a new GM 350 crate engine in. It has the Holley aftermarket throttle body. I did the initial break in and have had it out on the freeway a few times. It initially had some issues with rough running to the point that it would not stay running unless it was revved up. That was cured with finding a vacuum leak. It was miss firing in high RPM's. That was cured with a timing adjustment (it was at 16* BTDC, now it's at 9*. I guess I didn't tighten the bolt enough and it walked).
The thing I can't seem to figure out is the rough running in idle. I've cranked up the idle speed to 1100 when in nuetral to try to compensate. The idle speed when I shift into gear will drop down to about 600. This seems too low to me, but 1100 in neutral seems high. It smells like it's running rich, but when I try to lean it out it runs rougher. I do have exhaust leaks on both sides between the exhaust manifold and pipes. I assumed this was due to me not disconnecting the manifolds from the pipes during the swap, however it does spit out some black sooty stuff from the exhaust now, something it never has done before. Link to the system I bought: http://www.jegs.com/i/Chevrolet-Perf...353K3/10002/-1 I also replaced the starter, water pump, and alternator. I have exhausted my knowledge base on what to try next. Any suggestions would be appreciated.
It's not that I am apathetic, I just don't care. If your life is a joke, it appears death will be your punchline. |
Re: New Engine Idles Rough
I would call Jegs tech support.
72 Cheyenne super 10 08 3500 HD 4dr dually 12 ford flex (wifes ride) 76 Monte Carlo 83 Chevy short wide Silverado 96 Mazda Miata, 2000 Allegro Bus |
I'm not sure about the new motors but I had a 350 in my truck that the distributor hold down would not stay tight. I would adjust it ad it would rattle right back around after a few min. Not saying that's what your issues are but the symptoms are very similar.
-Sterling GIG EM' AGGIES!!!! WHOOOOOOP!!!!! "Whether you think you can or think you can't, you're Right." -Henry Ford 1972 chevy lwb 1934 ford p/u |
If you got a chrome dist hold down I would recheck the timing again and check again for vac leaks. It still sounds like you may have a vac leak. You may want to spray some carb cleaner along the manifold rails and around the base of the EFI unit to make sure it is sealed. Jim
![]() Join Date: Jul 2013
OH, I see what you did there! The Holley EFI system. OK, I do not have direct knowledge of this system, but Something is not "LEARNED" correctly. The system is dumping fuel at idle.
You might have already done this, but 20 years of troubleshooting robotics and industrial electronics tells me to start at square ONE and check all the dummy stuff first. Jegs tech support is going to have you do this anyway. Pull out the install manual and start over re-tracing every step to make double sure you did not screw up. I do technical support now and trust me.... it is always something simple that got over looked.
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
I haven't had time to fool with her, yet. But, there was a new development. The other day when I went to shift, the tranny made a noise similar to the noise you get if you forget the engine is running and engauge the starter, while it was shifting. Could this be indicative of a vacuum leak? Maybe that is what the idle problem is related to (like someone suggested). It only did it on the first shift into reverse and then into drive.
Active Member
![]() Join Date: Jul 2007
Not sure about the noise when shifting, but as mmiddle mentioned the running rough, black sooty stuff out the exhaust sounds like running rich. I'd concentrate on that first. You should see the dark gray smoke coming out the exhaust.
The vacuum leak possibility can be checked fairly easy with a short piece of garden hose (my favorite stethoscope) or by plugging all the intake and carb vacuum lines and checking the idle again.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
#8 | |
#9 | |
*** That's interesting ***
Another possibility is that you may have heard pump whine for a moment internally in the transmission. I've had various transmissions do this after a cold start over the years, usually only happens for a moment (approx 1 second), and usually only happens once per drive, but is not consistently reproduced unless the pump is going bad or some other problem. This won't sound like a starter grind, it will sound more like a power steering pump groan.
Tom ![]() Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... Last edited by storm9c1; 01-22-2014 at 07:47 PM. |
