Old 01-19-2014, 11:08 PM   #1
AJs72K5
AJs72K5's Avatar
BBC Edelbrock Pro-Flo Multiport FI
Selling my Edelbrock MPFI setup. Model 3550. BBC, big oval port, 44lb injectors. Complete minus fuel pump. New O2 sensor and water temp sensor. Includes proper Mallory electronic distributor with new cap.
System was bought used and I haven't run it. Going a different direction.
SOLD
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 01-20-2014, 07:51 PM   #2
ecgate
ecgate's Avatar
Re: BBC Edelbrock Pro-Flo Multiport FI
Do you have everything needed other than the pump to install and run this set up. And if not what else does it need to be a complete kit?
ecgate is offline   Reply With Quote
Old 01-20-2014, 09:12 PM   #3
AJs72K5
AJs72K5's Avatar
Pump, fuel lines, and a chip should be it. You will need to get a chip burned based on your cam, engine setup, etc. Edelbrock tech support, or a good local dyno shop, can point you in the right direction on that.
It was bought from a board member several years ago. He removed it from a running truck. I just never got around to fully installing it.
- AJ
Old 01-22-2014, 10:01 PM   #4
AJs72K5
AJs72K5's Avatar
bump.
- AJ
Old 01-26-2014, 12:34 AM   #5
AJs72K5
AJs72K5's Avatar
Ttt.
- AJ
