Old 01-20-2014, 01:11 AM   #1
88lsiroc
88lsiroc's Avatar
Suburban Tahoe plastic tank demensions
I'm in the process of starting an ls 4.8 or 5.3 swap. I was thinking of using a newer 99 up burb Tahoe plastic tank for reliability and dependable parts. Has it been done? does anyone have the dimensions? I've looked high and low with no answers. Thank you for any info.
88lsiroc is offline   Reply With Quote
Old 01-20-2014, 03:44 AM   #2
motorcritter
motorcritter's Avatar
Re: Suburban Tahoe plastic tank demensions
I saw on a K5 board that a '99 Tahoe tank is 30"x22"x14"- the guy said that was not exact dimensions, but close enough to gauge what space it would fit in.
If 'that which does not kill me, makes me stronger', then I should be Superman by now!
motorcritter is offline   Reply With Quote
Old 01-20-2014, 11:59 AM   #3
88lsiroc
88lsiroc's Avatar
Thanks for the info. I was looking at older burb tanks. Then my mind wandered. Why not use the newest most reliable parts and also easily accessible when you're on the side of the road.
Old 01-20-2014, 01:30 PM   #4
dyrt
rockauto lists this:
2 door; 30-1/2" x 24-3/4" x 14"
dyrt is offline   Reply With Quote
Old 01-20-2014, 05:31 PM   #5
Lees68GMC
Lees68GMC's Avatar
My friend Tim just did a 5.3 Vortec and used the Tahoe tank, fuel pump, gage, everything. worked perfectly
68 GMC SWB Vortec 5.3
98 Chevy Blazer ZR2
94 Mazda Miata, LS2 6 speed, sold
"No matter what happens, nobody gets out alive"
Lees68GMC is offline   Reply With Quote
