01-20-2014, 01:17 AM | #1 |
Optimal Tire Diameter
Hi Everyone,
What diameter tire will yield optimal performance on my truck??? After searching and reading through many of the topics based on rear differential gear ratio and tire sizes I am still stumped, this may be a result of me being a rookie in regards to rebuilding vehicles. I also tried to use the online calculators but am still stumped. I have a 1968 short bed c10. According to the previous owner, the engine and tranny (TH400) was transplanted from a 1969 Camaro z28. The original rear differential was a 3.08, which I have since replaced with a 3.42 (much more responsive now). I am doing a little of city and highway driving, and some light hauling. I recently purchased 15x8 stock rally wheels that will replace the current aftermarket 15x8s. So my question is what diameter tires would give me optimal performance (power and mpg) if I am cruising at about 65-70 mph on the highway? I am leaning towards 255/70/15, a diameter of 29", would this be ideal? Any input is much appreciated. I am very grateful for the wealth of knowledge from members on these forums, and hope to contribute during my rebuild. Thanks! |
01-20-2014, 03:38 AM | #2 |
Re: Optimal Tire Diameter
There are a few apps that you can get to determine tire diameter. A 29" tall tire would be pretty optimal for all-around use. That would be that 255/70R15 or a 235/75R15. It comes down to what size rims you're running and what kind of ride, handling and economy (tire life & fuel mileage) you want to have. These trucks are pretty much a blank canvas, and it can be tailored as you see fit. This forum is probably the best one I've seen on the 'net- and I'm on a whole lot of them. Any question you got, someone's got the answer- or a bunch of answers from a bunch of folks. Originally, most of the 2WD trucks ran tires about 2" shorter than the ones I listed- OE size was G78-15, roughly equivalent to a 205/75R15. I would never run something that small on one of these trucks. I've found that a 235/75R15XL gives good performance all around, just my experience.
If 'that which does not kill me, makes me stronger', then I should be Superman by now! |
01-20-2014, 03:49 AM | #3 | |
01-20-2014, 12:01 PM | #4 |
I have 235/75/15's on mine. ..and I have no complaints about them at all. Good ride and seems to do ok on gas. .. well as good as possible for old trucks
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son |
01-20-2014, 02:02 PM | #5 |
70+ ( Old Skool Club )
I have 255/70 R15's on 15 x 8 rally rims on my stock height truck and I do lots of compliments about the stance. The 255's work super with an 8 inch rim.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
01-20-2014, 02:03 PM | #6 |
easy to use calculator here: project33.com
01-20-2014, 02:23 PM | #7 |
01-20-2014, 04:46 PM | #8 |
3rd
01-20-2014, 05:23 PM | #9 |
I'm running 27" tall 275-60-15 BFGs, 3:42 gears, removing a Turbo 400 and installing a 700R4 trans. 700 has lower 1st gear plus 4th over-drive for some mileage. We'll see how it works
68 GMC SWB Vortec 5.3 98 Chevy Blazer ZR2 94 Mazda Miata, LS2 6 speed, sold "No matter what happens, nobody gets out alive" |
01-20-2014, 05:39 PM | #10 |
That combo should work super for you.
01-20-2014, 07:51 PM | #11 | ||
01-20-2014, 07:53 PM | #12 |
01-21-2014, 12:02 AM | #13 |
01-21-2014, 12:08 AM | #14 |
He has a picture of his truck in post #9.
01-21-2014, 01:18 AM | #15 |
That's because power glides are 2 speeds.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
01-21-2014, 01:35 AM | #16 |
There is no magic diameter. This is more a matter of compromise. A short tire will give better acceleration, since it yields a lower final drive ratio, but the same tire wont return the best mileage. In my experience, you wont see much noticeable difference in performance and mileage in 235/255 tires. Personally I am running 275/60r15 because I like the look of a filled out wheel well.
BTW, 67-69 z/28's only came with 4 speed manual transmissions. Im surprised the previois owner didn't tell you it had the "Corvette engine" we have all heard so much of. :lol |
01-21-2014, 01:50 AM | #17 | |
01-21-2014, 02:18 AM | #18 |
Wow, I don't check the forum for a while and the crowd shows up! As to my rear axle ratio, the '70 C10 has 3.73, I haven't bothered to check the '71 Cheyenne yet (after 2years of driving it), but I get poor mileage, no matter what. So, the C10 will get late model injection, the Cheyenne is a 402 Sultan's Favorite (and left all original @ 54K original miles) and the '68 GMC doesn't have an engine yet.
01-21-2014, 03:14 AM | #19 | |
01-21-2014, 01:23 PM | #20 | |
Thanks, Jim
Thanks, Jim - 69 Short Step CST 350 AC/PB/PS - 69 Short Step 307 Man Column/PS |
01-22-2014, 12:17 AM | #21 | |
01-22-2014, 12:29 AM | #22 |
Truck is dropped 3/4. A picture is worh a thousand words.
01-22-2014, 12:33 AM | #23 |
No rubbing bottoming out or other issues. She does mark her territory, though!
01-22-2014, 12:42 AM | #24 |
Una mas
01-22-2014, 12:45 AM | #25 |
I've checked my speedo against my GPS and with the speedo at 95MPH the GPS was showing 93 MPH and that is close enough for me.
