Blue 67
![]() Join Date: Apr 2004
Is your shop connected to septic system?
He guys:
We are shopping for a house and everything we are looking at is on septic system. Many of the houses that we are looking at have some kind of shop ![]() Thanks.
1953 GMC 3/4 ton: current project 1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake 1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!! 1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive 1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project 2005 Silverado 2500, 4x4 Duramax, original owner |
Re: Is your shop connected to septic system?
My shop has a full bathroom and washer and dryer hook up that was in part because I lived in it for a few months while I finished building my house. I am on a septic tank now I don't have a floor drain or anything that might flow the bad junk into my system I will wash up in there but that is not much worse than what most will do in their house.
My buddy added a sink to his shop recently and it is considered "gray" water so it just drains outside it is the same as washing your hands at an outside hydrant It is just convenient to get water there or rinse your hands. There may be different regulations in different states or areas. If you have water in your shop and it gets cold you will need to heat that area or completely drain it. It is nice but I don't really find myself using alot of water in there.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
i just spent this weekend putting in a new septic system at my "barn". the only reason is i am adding on where the old septic tank was.
like Custom said above.... what goes into the septic tank is pretty much like what goes into my house system... i have a small bath room (commode and sink).. let me tell you, it is nice to not have to RUSH up to my house to use the John. i have missed it during the recent down time... i dont put grease or oil down my sink.
As a licensed septic installer for over 25 years, (& a MA Title V Septic inspector since the inception of that law,) I can tell you that grease is the enemy of any septic system, it gradually creates an impermeable slick where the drainage or leaching field meets the surrounding soil. That said, it is quite true that ordinary hand washing, will doubtless put less grease into the system than your kitchen sink and dishwasher do, and it would take many, many, years for that to affect the leaching. The bacterial activity in the tank does break down and consume some of the grease that enters the tank. You sure wouldn't want, however, to be washing any additional grease down the drain, like rinsing parts or such, which does seem obvious. (and NO floor drains) If you were to connect to an already existing field, which had some grease buildup already from age, this could hasten the demise of the system. If you expected to put an abnormal amount of grease down it, you could install a grease trap before the septic tank, such as restaurants have, but this would be pretty extreme. For a shop with a toilet and a hand washing sink, just being careful would certainly suffice. Local or state laws may dictate if this is allowed, if there is already a system on the site, as well as setbacks from water supplies (yours and any neighboring) Just my 2 cents.
The Older Generation
The thing to remember about a septic system is to not flush ANYTHING that will not dissolve, period! LockDoc
So Leon, are you telling me that Matchbox cars shouldn't be flushed?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
#7 | |
![]() LockDoc
#8 | |
blood type; Retumbo
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
Blue 67
Thanks guys.
Oil is lighter than water so it will float to the top of your septic tank and be dispersed through your leach field and exit the system through the ground (leach field).
i've been on well and septic for 32 years at 2 different houses.
in my first home shop i used a plastic 55 gal barrel with a lot of holes drilled into it and a truck load of gravel around it in a hole for my septic tank. i only drained my sink into it. in this shop i just have the pipe run thru the wall behind my sink. other than grease on my hands, i would never flush any grease or oil down a drain. any where. imo... floor drains in a garage are a waste of time and effort unless you have a dedicated wash bay. even then washing oil or grease into a drain is just wrong.
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#13 |
I have septic for my house and my detached garage. They are two separate systems though. Mainly was hands and flush toilet in the garage. I live in AZ so in the summer if I don't use the sink or toilet much the water evaporates out of the P trap and can make things smell. Works great though much better than having to go inside the house all the time.
