Need help with Exhaust!
Hey guys,
I need a little help installing exhaust for my 98 5.7 ext cab sierra. Currently Im looking at a flowmaster super 50 series , 2.25'' dual in/3.00'' center out with a turn down. I just need to know the stock exhaust size coming from the cats so can buy the right adapters. Later I plan on doing some engine mods and going with headers and true duels with and x pipe and 2 flowmasters. |
Re: Need help with Exhaust!
I believe stock exhaust is 2 1/4" all the way through. That was what was on my '96 when I bought it.
Austin 1996 Chevrolet K1500 Silverado ![]() 1979 Chevrolet K10 Scottsdale - Carolina K10 - My 4.8L Twin turbo build - Project Short Stroke - Instagram - TheBlueBomber1996 |
thanks, guess i could use my calipers to measure the outside and subtract the wall thickness......duh
my 97 ecsb Z71, right at the dual inlets of the stock muffler each pipe is 1 7/8", i'm sure its same up to cats. 2" id to 2.25" adaptor will leave a small gap to fill with the welder on the original pipe.
Yup, I measured them earlier and they are 1 7/8", from the muffler to the cats and I'm sure they are the same to the manifolds.
Thank God you didn't listen to me then haha.
hehe, ya, but thanks for trying bluebomber
My manager always says... "It's not about if you win or lose, It's how you prepare for the game".....
I guess I made him proud on this one.
Anybody know of a store bought y collector that will fit on the pipes behind the cats?
![]() Join Date: Aug 2012
You will probably have to have it made at the muffler shop of choice...Ive looked for a y pipe... If your going to change it later why not just wait and do it then?
I went and replaced the front pipes with a flowmaster kit and high flow cats, now im adding this. http://www.summitracing.com/parts/wlk-54020 and two Aerochambers dumped over the rear axle........... Im running a DI/SO flowmaster 50 series now.... Me no likey |
Thanks blue...
Does anybody now if I can completely remove the cats from a 97 5.7 liter, I can only see one set of o2 sensors in front of the cats, and I have been told that its okay like that. But Ive also been told the truck will still run a little rich with the cats removed?
#13 |
On my 97,I went with the 50 series then 4" chrome tips out the back,way too loud for a stock engine. Have since added baffles in the 4" tips,now it sounds good. Didn't notice any change in performance or mpg.
#14 |
where were your o2 sensors at before, and did you remove the cats?
#15 |
I left them on. I wouldn't remove them unless they're going bad.
#16 |
what about high flow cats? truck has 120k on it now and since im already here i might as well replace them right...
#17 |
#18 |
thanks guys,
Well i found a 50 series delta flow the other day in the junk yard, paid 35 dollars for it, it 3''in/3''out, so im not ever sure in i can use it without having a custom y pipe made to come from the cats to the muffler. If I were to buy a high flow cat at 3''in/out, I could just have them y it at the bottom of the drop pipes and tuck the cat nicely, then I could (weld this myself) extend 3'' pipe straight back to the flow and put a turn down on it.... I would get both a new cat, and a new muffler, for around......let see 100.26 +tax for the cat 35.00 for the muffler maybe 100. to install thats only 235.+/- for a complete system... |
#19 |
Anybody have a diagram of the o2 sensor locations on my truck?
#20 |
#21 |
Okay thanks, Ive looked for them behind the cats, and i cant see them anywhere, just one on each down pipe...
#22 |
#23 |
Thanks, I'll go look at it now
#24 |
Well I found them, I have four,
, so no high flow cats for me, I'll just put on a nice flowmaster with aggressive sound to overcome the restriction from the cats....
#25 |
What's a good aggressive sounding flow for the 5.7 Liters?
I did a little looking, maybe a super 40? Last edited by lucky_7; 06-18-2014 at 10:40 PM. |
| Bookmarks |
