Old 01-20-2014, 08:59 PM   #1
nickbwilson
Gauge cluster question
Hey guys I'm doing a ls swap in my 85 c10 I'm using the 91 suburban cluster does anyone have any idea what the light socket plug with two white wires and one black wire is for I've looked all over and can't find any info thanks in advance
nickbwilson is offline   Reply With Quote
Old 01-20-2014, 09:35 PM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Gauge cluster question
I'll take a wild shot in the dark.........a mistake....or something that outputs two different levels (hi/lo) of light?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 01-20-2014, 09:51 PM   #3
ls1nova71
ls1nova71's Avatar
Is the socket on the 85 harness or in the 91 cluster? Could be a choke light or maybe a check engine light?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 01-21-2014, 08:52 AM   #4
nickbwilson
Its on the 91 cluster only reason i'm asking is I just got my gauges wired for my LS swap and I don't have any dash lights my gauges move and my seat belt and brake light come on just know other lights my headlights wont come on but i have turn signals im using a PSI conversion harness
Old 01-22-2014, 03:13 PM   #5
Jonboy
Slots go on anything!
Did you move any of the wires in the plug? You will probably need to get the correct wires in the plug for the '91 cluster. GM is pretty good about keeping the colors the same for the circuits, but they may be in different cavities on the I/P cluster plug.
1974 Jimmy- 5.3/4L80e/NP241
Old 01-22-2014, 03:23 PM   #6
nickbwilson
Jonboy i did move them around im going to double check everything tonight to make sure i put them in the right slots
