Old 01-21-2014, 11:00 AM   #1
blazer2007
raising wheel rear tubs
I was wondering if you still used the inner wheel tub skirt[the small piece between tub and body panel] when you raise the bed floor, and how did you re -attached the tub ,weld it or tack weld with body sealer.My tubs are a little rotten ,can I use other ones from trucks ?
blazer2007 is offline   Reply With Quote
