Old 07-19-2003, 11:53 PM   #1
69 Big Block
Must get more toys!!!!!!!
69 Big Block's Avatar
Question Question about brake job gone bad!!!
Replaced the shoes, wheel cylinders, Master Cylinder and Power Braker Booster. Bleeding was completed with an air powered power brake bleeder. Now when you apply the brakes the damn thing whistles and spits brake fluid out from under the master cylinder cover. Where the heck did I go wrong?
69 GMC 3/4 Ton Custom Camper
396 / Turbo 400 w/shift kit!!!!!
She's all there and solid as a ROCK!!!!!
69 Big Block is offline   Reply With Quote
Old 07-20-2003, 12:05 AM   #2
knucklebuster
Failure is NOT an option!
knucklebuster's Avatar
Make sure the top is seating on the master cylinder good.it may have a factry flaw in it.Check it with a straight edge and if it's off take it back or use a file to level it but make sure you put a rag in the cylinder to keep shavings out
House payment or truck parts?????.........why does life have to be so complicated?
1969 Chevy Shortbed Fleetside
1969 Camaro ps pb a/c(drove in high school now it's just a yard ornament,but it's next on the list for resto)
1990 Ni$$an hardbody( daily beater that has been really beaten!)
1999 Grand Am GT(wifes ride...never buy a pontiac!!Trust Me)
knucklebuster is offline   Reply With Quote
Old 07-20-2003, 03:44 PM   #3
nu2-72
And make sure the rubber seal is good. Did you bleed the master before you did the rest of the brakes.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 07-20-2003, 09:32 PM   #4
Class of 69
Class of 69's Avatar
I'm concerned about how much pressure was applied by the pressure bleeder. If I remember correctly, they only need about 30 lbs to bleed the system. They will all spit fluid up into the reservoir, but I've never heard one whistle. Maybe the whistle is coming from the booster? I agree with knucklebuster, and nu2-72 about the cover and gasket seating squarely, and tightly.
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 07-20-2003, 10:09 PM   #5
knucklebuster
Also check the little rubber grommet on the booster that could be the whistle
Old 07-21-2003, 08:19 AM   #6
69 Big Block
Thanks for the replys. I've never seen one or had any one tell me of one doing this before. I figured I just flat screwed up!!! Anyway, I hope to be under the hood tonight checking these issues out.
Thanks for the replys!!!
