Old 01-22-2014, 03:23 AM   #1
PushnFords
Custom Camper factory solenoid?
I just bought a '72 C20 Custom Camper with the 400/402. On the driver's side inner fender right by the P/S reservoir is a Ford style starter solenoid. One wire goes across the radiator support to the battery, one is coiled around the solenoid, and one goes to a little metal relay screwed to the rad support at driver's left lower corner of the radiator. I don't want to rip that stuff out & toss it if it might be factory.....
1999 Tahoe LT 4dr
1971 Torino 4dr
1954 GMC 100 5 window - Project
PushnFords is offline   Reply With Quote
Old 01-22-2014, 11:30 AM   #2
JimKshortstep4x4
Re: Custom Camper factory solenoid?
I believe that your truck may have(or had) the dual battery setup and someone installed the solenoid. Here is a schematic of the dual battery wiring and components so you can compare what the factory did against what you have.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 01-24-2014, 01:37 AM   #3
CCCC
CCCC's Avatar
Ditto what JimK says - installed such a setup on a 72 C30 Mohome here.
CCCC
67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison
Moved but still in the family
70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350
Recently sent to new homes
72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp
CCCC is offline   Reply With Quote
Old 01-26-2014, 03:37 AM   #4
PushnFords
That diagram mostly matches up. I have the passenger side junction block still but don't see the driver's side one anywhere. Also missing the battery tray itself but there are a couple of bolts in the radiator support where it might have attached.
Wife is mad that I bought this truck...well actually the '72 C20 that I traded for this truck. My favorite year and I'd never owned one...at this point I'm just hoping to break even. But at least I can say I've owned two '72s. lol
1999 Tahoe LT 4dr
1971 Torino 4dr
Old 01-26-2014, 12:13 PM   #5
JimKshortstep4x4
The relay looks like the original relay and the two bolts shown in your picture are the the ones used for the right side of the battery box. Someone has obviously installed the starter solenoid.
Jim
Old 01-26-2014, 02:39 PM   #6
PushnFords
Oh I thought the diagram was showing the starter relay at the lower corner of the aux battery.
1999 Tahoe LT 4dr
1971 Torino 4dr
