01-22-2014, 03:47 AM | #1 |
Lowering Questions
I have been looking and asking question in a bunch of different threads, and have not seen any really good or proven answers.
Is there a point when lowering a 1964-1966 Cheverolet C10 that you need a adjustable track bar? What is the point in inch's when lowering a 1964-1966 Chevrolet C10 will you need a frame C-Notch? Thanks. |
01-22-2014, 05:23 AM | #2 |
Watch out for your cornhole !
Re: Lowering Questions
Adjustable track bar needed when lowered >3 inches
C notch when lowered >6 inches
01-22-2014, 10:18 AM | #3 |
My personal opinion is an adjustable Panhard should be used w/any drop. If going over 3" of drop, I would recommend swapping to the 'long' aftermarket (or home-built) set-ups to minimize side shift (the longer the bar, the less side shift).
C-notches when over 5" of drop.
01-22-2014, 11:17 AM | #4 |
Ok, thanks for both of your answers.
I have been thinking about 3" Front Springs with 4" Rear Springs. At what point in lowering a 1964-1966 Chevrolet C10 do you need Rear axle shims, or angle shims? |
01-22-2014, 12:08 PM | #5 | |
I would also recommend that on any drop over 4" to buy a shock relocation kit to get the shocks back to the correct angle. Also remember that the higher in drop you go on the rear coils, the mushier the ride is going to be. If you plan to use the truck for light hauling use, you may want to consider a coil spring/lowering block combination to get the drop number you need. One of our board members (Boris, aka: way2lo2) sells an excellent solid billet aluminum lowering block and u-bolt kit that is substantially stronger than the extruded aluminum blocks you see on ebay. I think Boris sells them in 1" and 2" versions. I wouldn't use a 3" block because it could cause scrub issues if you ever lost a rear tire. I always double-check the pinion/driveshaft/transmission angle every time I lower a vehicle and add shims as required. Some vehicles I have done required shims, and some didn't, but it's always good to check.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
01-22-2014, 01:12 PM | #6 | |
What is a Good Quality company to buy Lowering springs front and rear = ? Shocks for lowerd truck = ? Blocks = way2lo2 Track Bar = ? Frame C-Notch = ? |
01-22-2014, 01:17 PM | #7 |
67-72 parts collector,…
www.earlyclassic.com for all your parts.
01-22-2014, 01:20 PM | #8 | |
Just remember that these springs are 3" and 4" shorter than brand new replacement stock height springs. Not your 40+ year old sagging springs. So if you just measured your truck and thought is should be 3" shorter in the front,... don't expect these springs to lower YOUR truck by that amount. I usually tell members to find a truck on here,... that has the drop YOU like,... and drop yours the same amount. I expect your original springs are sagging at least 1"-2" from stock already.
01-22-2014, 02:15 PM | #9 |
Happy to be here
I suggest you go ahead and do the C-notch and longer track bar. Your going to need it when you lower it more the second time.
01-22-2014, 07:19 PM | #10 | |||
Thanks. |
01-22-2014, 07:29 PM | #11 | |
GearBoxGarage for the OE length/position Panhard bar.... http://67-72chevytrucks.com/vboard/s...d.php?t=550494
01-22-2014, 07:35 PM | #12 | ||
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
01-22-2014, 07:38 PM | #13 | |
http://www.earlyclassic.com/Tech.asp...=Stance+Photos
01-23-2014, 01:22 PM | #14 |
Thank you all for the great information.
