Old 01-22-2014, 01:55 PM   #1
hardwaycooke
hardwaycooke's Avatar
What size pipe to use for upper RAD hose replacement
Want to get stainless pipe to replace upper RAD hose. I know I use 1 1/2 hose for upper but thats ID, right??
What size pipe should I get??
Thanks in advance.
hardwaycooke is offline   Reply With Quote
Old 01-22-2014, 02:12 PM   #2
Fitz
Re: What size pipe to use for upper RAD hose replacement
Thanks in advance.
I used 1 1/2 and that's the same ID as your hose.
Fitz is offline   Reply With Quote
Old 01-22-2014, 05:39 PM   #3
hardwaycooke
Where did you get the pipe?
Old 01-22-2014, 05:49 PM   #4
67 cst swb
67 cst swb's Avatar
be sure you put some sort of ridge or lip on each end if you make a pipe.
If your system builds up too much pressure, it could blow the rubber hose off the metal pipe.
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 01-22-2014, 06:10 PM   #5
Fitz
Just TIG welded it up from two 90 degree bends with a ring of 3/16 stainless filler rod for the lip to hold the elbows on.
I get mine from : http://www.burnsstainless.com but JEGS, Summit, Vibrant has it as well. Silicon elbows from: http://www.siliconeintakes.com
Old 01-22-2014, 09:08 PM   #6
Tinkermc
lookin gooooooood !!!!
Tinkermc is offline   Reply With Quote
Old 01-22-2014, 10:33 PM   #7
74baggedbug
I'm still trying to find someone local to make 1
74baggedbug is offline   Reply With Quote
Old 01-22-2014, 10:45 PM   #8
Unionwelder
Unionwelder's Avatar
What part of Houston? I'm about 1 1/2 hrs away, might be able to help you out.
-Sterling
GIG EM' AGGIES!!!! WHOOOOOOP!!!!!
"Whether you think you can or think you can't, you're
Right." -Henry Ford
1972 chevy lwb
1934 ford p/u
Unionwelder is offline   Reply With Quote
Old 01-22-2014, 11:02 PM   #9
74baggedbug
Well really deerpark but not many folks know where that is .. Other side of Pasadena .. Southeast area
Old 01-22-2014, 11:05 PM   #10
Unionwelder
Ok so more like 2 1/2... I'm gonna make one for my truck this weekend ill pm you when it's done. Won't take 20 mins to do one with the orbital welder. Might be able to do 2
-Sterling
Right." -Henry Ford
1972 chevy lwb
1934 ford p/u
Old 01-22-2014, 11:25 PM   #11
74baggedbug
Ok lmk thanks !!
