Old 01-22-2014, 02:34 PM   #1
oneoff
oneoff's Avatar
Questions on integrating different years??
Can you bolt a 67-72 body on a 72-87 4x4 chassis?
Build: http://67-72chevytrucks.com/vboard/s...d.php?t=541803
Dennis H
1969 Chevy C10, SWB, LS3,6.2L engine
1969 Chevy Chevelle SS,BBC, Convertible
oneoff is offline   Reply With Quote
Old 01-22-2014, 07:54 PM   #2
nekkidhillbilly
Re: Questions on integrating different years??
ive seen 50s trucks on a 80s 4wd frame sure it require some welding though
nekkidhillbilly is offline   Reply With Quote
Old 01-22-2014, 08:09 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Not easily.
The 73-87 trucks have a significant kick up in the frame under the cab. Remember, the fuel tanks on the 73-87 are under the cab, so it has a raised floorboard and higher frame rails in that area.
Old 01-22-2014, 08:17 PM   #4
nekkidhillbilly
burban tank is cure
Old 01-22-2014, 10:53 PM   #5
Tx Firefighter
It doesn't cure the shape of the frame rails though.
Old 01-22-2014, 11:30 PM   #6
KrazyRay
KrazyRay's Avatar
There is also a longer wheel base on the 73-87.
KrazyRay is offline   Reply With Quote
Old 01-28-2014, 03:04 PM   #7
oneoff
oneoff's Avatar
Just thought it might make things easier, oh well I am planning on a new build!!! I think long and hard about what I do in building a car/truck. I'm thinking of building a 71/72 4x4 chassis with 67/68 body, factory a/c, cab, P/S, PDB, BBC with automatic. I'll be using all factory date correct stuff and it'll be a daily driver, especially in the winters of Colorado.
I'm going to accumulate parts over the next year or so and build this project in record time. Any help od assistance would be welcome....
Dennis H
Old 01-28-2014, 08:22 PM   #8
nekkidhillbilly
it still could work just have to build the right body mounts. ive even seen a 70 c20 on a new 2500 hd frame, me id convert your stock frame to 4wd.
