Old 07-20-2003, 12:55 AM   #1
Chevy4Life
Chevy4Life's Avatar
Question Bolt-in LOW HUMP???
My 67' has a HIGH HUMP cab. I want to convert it to a low hump, and recently read that SOME 2wd blazers had a bolt-in LOW HUMP, does that hump fit the trucks?
Chevy4Life is offline   Reply With Quote
Old 07-20-2003, 01:14 AM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Why do you want to convert??? It make's it easy for tranny work.
Just my 2 cent's worth.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 07-20-2003, 01:31 AM   #3
Chevy4Life
Chevy4Life's Avatar
I just like the flatter floor, and it will get some kind of bench seat so the more leg room the better.
Old 07-20-2003, 01:34 AM   #4
Chevy4Life
Chevy4Life's Avatar
Also, if it means cutting out the high hump and welding in a low hump I may just keep it the way it is. But if I could just bolt-in a low hump and find one I will definately do that.
Old 07-20-2003, 09:29 AM   #5
crazy longhorn
Fabricate till you "puke"
I dont think you will find a bolt in low hump, all i have seen were a pc of the floor. You may be able to set up a bolt in low hump, if you cut the hump from a donor cab + a little extra floor to trim to fit. just trim to fit, & drill the holes? Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 07-20-2003, 01:17 PM   #6
jay-dawg
chevelito
jay-dawg's Avatar
my thoughts exactly
New deadline...when my son can drive.
Aloha from Honolulu, HI
jay-dawg is offline   Reply With Quote
