16x10 wheels on a 71 K-10? Will they fit?
Looking at putting a 4" Lift with 16x10 wheels with 4.5 backspacing. Are there any issues with the 16s rubbing the drive train components. I know all of the outlets only list 15" wheels for 67-88 (I assume because that was stock) and LMC Trucks has a few 16" wheels for sale but it says they will not fit 4WD? Anyone know if there are issues?
Thanks for any insight. |
Re: 16x10 wheels on a 71 K-10? Will they fit?
You probably should have posted this in the 4X4 section along with your year of truck, disk or drum brakes, and is it a K10 or K20 ect. I don't have a definitive answer for you, i saw one post where it looked like a 16" rim would clear the caliper but don't recall the rim width or back spacing or if it was 2wd or 4wd.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
OOps - I thought I was in the 4x4 section. This is my first post. Title says 71 K-10. It's a 1971K-10 1/2 ton 4WD. It has disc brakes. Thanks,
Ok my bad on the title, guess its front disks then.
Oh, you could ask a mod to move this thread for you, they don't like double posts
