Old 01-23-2014, 07:12 AM   #1
Jmiller022
Jmiller022's Avatar
fuel cell foam
Im looking at getting some fuel cell foam to help with the movement of my full when the tank gets below half full.
Mine is a 16g RCI fuel cell.
Are there a certain # of pieces of foam I should get depending on the fuel cell size?
Will the foam mess with my sending unit for the fuel level?
Thanks for your help.
68' c10 stepper 5.3/4L60e
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=578917
Jmiller022 is offline   Reply With Quote
Old 01-23-2014, 08:30 AM   #2
Unionwelder
Unionwelder's Avatar
Re: fuel cell foam
Had to remove 1/2 the foam out of mine for the sending unit, summit has the foam I'm not sure of the amount as mine is a 12 gal.
-Sterling
GIG EM' AGGIES!!!! WHOOOOOOP!!!!!
"Whether you think you can or think you can't, you're
Right." -Henry Ford
1972 chevy lwb
1934 ford p/u
Unionwelder is offline   Reply With Quote
Old 01-23-2014, 10:37 AM   #3
stevencvn72
Kill Bill...et
stevencvn72's Avatar
Re: fuel cell foam
Just get enough to circle around your fuel pick up / sender.
-Steve
I Grease
'67 Chev stepper
http://youtu.be/38p_2Iu2fd0
stevencvn72 is offline   Reply With Quote
