Old 01-23-2014, 09:16 AM   #1
Unionwelder
Unionwelder's Avatar
Painted spid
Hey y'all,
Originally I thought i was missing my spid, however last night I opened the glovebox and saw the outline of the sticker. Someone in the past just painted it over, my question is if I use a stripper to take off the paint will it eat the spid too? Is there one that will work better than another? paint thinner dodnt do anything and I tried to sand it down a little but that just went straight thru the paper. All I'm really after is to see the codes so I can have another made. Thanks for any help.
Sterling
-Sterling
GIG EM' AGGIES!!!! WHOOOOOOP!!!!!
"Whether you think you can or think you can't, you're
Right." -Henry Ford
1972 chevy lwb
1934 ford p/u
Unionwelder is offline   Reply With Quote
Old 01-23-2014, 10:47 AM   #2
alsriv2
alsriv2's Avatar
Location: Formerly MD and San Diego, now loving life in Arizona
Re: Painted spid
I have the same problem with my truck and posted in a thread on this subject sometime last year.
Basically, if you have a newer model '71-'72? The spid might have a plastic coating that might allow you to remove the paint and save the spid. However, if yours is one of the plain paper ones like the one I have, there is probably no hope in recovering the original. The good thing is you can evaluate your truck and create a spid to your liking.
Alan
2012 Ram 3500 Dually Crew Cab 6.7 Cummins
2014 Palomino Columbus 340RK 5th wheel
'69 Chevy C10 396BB
alsriv2 is offline   Reply With Quote
Old 01-23-2014, 10:52 AM   #3
sanford&daughter
sanford&daughter's Avatar
Re: Painted spid
I think paint stripper will be to harsh and wouldn't recommend that if it doesn't hurt the spid I'm sure it will mess up the ink with the codes. I would try and call someone in the line of painting restoration to see if they can recommend something less harsh
sanford&daughter is offline   Reply With Quote
Old 01-23-2014, 11:56 AM   #4
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Painted spid
Try some nail polish remover (acetone) on the lower portion of the SPID...If that dont work, try enamel reducer or lacquer thinner...Maybe try some break fluid as well...You can also try a very fine wet sand paper or steel wool to work the paint off without destroying the SPID below...At least enough to read and copy the original and have a new one made...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 01-23-2014, 01:04 PM   #5
bowhunter65
Re: Painted spid
X2 on the acetone
bowhunter65 is offline   Reply With Quote
Old 01-23-2014, 01:58 PM   #6
Mike's money pit
Re: Painted spid
I don't know if it is possible to carefully peel the spid off, but if you can I bet a light held behind it will allow you to read it.
Mike
Mike's money pit is offline   Reply With Quote
Old 01-23-2014, 07:49 PM   #7
Unionwelder
Re: Painted spid
Thanks for the replies y'all, the acetone worked enough to read the codes. I really appreciate the info, I can do anything with metal but paint isn't my thing.
-Sterling
Right." -Henry Ford
1972 chevy lwb
1934 ford p/u
