01-23-2014, 01:01 PM | #1 |
Cold TH350 not shifting into reverse
Hi all,
I have a 72 with TH350 auto transmission and for the last week reverse doesn't work when I first start it up. It's been cold weather out. I can get it to go backward but only by revving the engine up and it barely goes. All other gears work and it shifts normally going down the road. Reverse starts working after the engine temp starts to come up (usually after I've driven it about a block or so). The fluid was a little low, so I added a pint. I haven't had a chance to check the fluid level again since adding ATF, but it's still not shifting into reverse at start up. Any ideas what might be happening? Thanks, Craig.
1972 C-10 Deluxe 350 V8 - 350TH ------------------------------ We're not the jet set We're the old Chevrolet set |
01-23-2014, 01:08 PM | #2 |
Re: Cold TH350 not shifting into reverse
I'm afraid it's not good news. If the fluid is full and it's still not going when cold, you're likely seeing the last legs of the transmission.
And don't change the fluid thinking that will help. With older TH transmissions, that will often be the last nail in the coffin. You flush out some of the friction material that's keeping it going, and it stops working at all. |
01-23-2014, 01:20 PM | #3 |
Yep, the rubber seals that operate the clutch pistons are getting hard.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
01-23-2014, 01:31 PM | #4 |
Been there and done that on some th350's. Change the filter and fluid.
Kenneth
72 CHEYENNE 10 SUPER 468/400/3.73 |
01-23-2014, 06:58 PM | #5 |
As others have said on last legs, 1st will be next
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
01-23-2014, 07:13 PM | #6 |
I have heard that a bottle of Berrymans B-12 Chemtool will soften the seals and buy you a little more time...anyone try this?
01-23-2014, 09:46 PM | #7 |
I used trans x in mine helped a little bit
01-24-2014, 12:15 PM | #8 |
I didn't specify in the original post, but you guys were supposed to give me good news!
OK, I'm gonna throw out a couple of other tidbits that I should have mentioned before. I had the trans resealed about 2.5 years ago because it was leaking bad. I don't know if that included the seals on the clutch pistons or just what was required to stop the leak. The previous owner rebuilt the trans about 40,000 miles ago. Again, I don't know what that involved I just have an entry in his records that says 'rebuilt transmission'. Also, the engine is running a little cold according to the temp gauge. Maybe the thermostat is stuck open a little. I was waiting for some warmer (above freezing) weather to do this. The transmission starts working normally well below the top temp so I guess this may have nothing to do with the other problem. I will check the fluid level again this afternoon.
01-24-2014, 12:24 PM | #9 |
Also we have one vote for "DON'T CHANGE THE FLUID & FILTER" and one vote for "DO CHANGE THE FLUID & FILTER". Anyone care to cast the tiebreaker?
01-24-2014, 12:31 PM | #10 |
A "reseal" usually just is the external gasket to keep it from leaking fluid on the ground.
In a cheap rebuild, they just air check the piston seals and replace the leaking ones. The reverse seals are buried in the bottom of the case and the hardest to replace. It might be they never got changed. edit. I'm in the camp of changing the fluid never hurts. If the trans fails after a fluid change it was going to fail anyway.
