01-23-2014, 02:00 PM | #1 |
Backhalfing my truck and need a little help.
I got the new frame assembly set in between the stock frame rails. Now I'm just trying to square and level things up as best I can. What is the maximum allowable tolerance/difference? My main crossmember measures 6 23/32 to 6 25/32 on one side and the other measures 6 25/32 to 6 3/4. I guess it just depends who's measuring and how they hold the tool. I used both a laser measuring tool and a tape measurer. I'm about to go buy some plumb bobs to get my centerline mapped on the floor, I'm sure that'll help too.
Also, do I need to account for from suspension ride height? Most directions say to just get the chassis up in the air and level. I was wondering if I put my backhalf in a level height, would it change my ladder bar angle when I drop it down to ride height?
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs. Best time so far 11.8@XXXMPH |
01-24-2014, 08:50 AM | #2 |
Java Mechanic
Re: Backhalfing my truck and need a little help.
Obviously; the more square the frame is the better off you are. That said; I don't think 1/32 of an inch is going to present much of an issue. There is probably more flex and play than that.
Truck arms with a panhard do move from side to side when raised and lowered. Some other suspension systems do not. How are you set up?
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
01-24-2014, 04:25 PM | #3 |
It's gonna be ladder bars and I believe a track bar.
