Old 01-23-2014, 03:26 PM   #1
oldcane
brake booster question
I'm sure I should already know this but I don't. I found a '69 I'm trying to work a deal on and it has power drum brakes. I'm assuming the m/c is different if I go to discs but is the booster the same? If not and I get a new one will the mounting holes line up? Thanks.
oldcane is offline   Reply With Quote
Old 01-24-2014, 01:27 AM   #2
luvbowties
luvbowties's Avatar
Thumbs up Re: brake booster question
Booster oughta work ok. Be sure its shaft mates correctly with mc where the mc MAY or MAY NOT have a bore in its piston, in which case the booster shaft must extend beyond its mating surface to where it nearly bottoms out at the end of the bore; & vice versa.
Sam
luvbowties is offline   Reply With Quote
