Old 01-23-2014, 04:12 PM   #1
dhc871
dhc871's Avatar
Replace my bench seat
69 GMC C1500 stepside needs a replacement seat. What later model bench or bucket fit this truck?
1969 GMC SWB
dhc871 is offline   Reply With Quote
Old 01-23-2014, 04:31 PM   #2
brad_man_72
the boat guy
brad_man_72's Avatar
Re: Replace my bench seat
None newer than 72 will bolt in. Many will fit with modifications.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 01-23-2014, 09:56 PM   #3
19GM71
19GM71's Avatar
I have seat out of a 91 chevy truck that has the arm rest and the loop looking head rests in my truck. It only required drilling two new holes for the rear of the seat bracket. I was able to line up the front holes of the 91 seat bracket with the existing front factory holes in the floor, which allows the front of the seat bracket to sit on the hump in the floor of your truck giving the seat a slight tilt down in the rear. I like the way this seat sets.
19GM71 is offline   Reply With Quote
Old 01-24-2014, 01:07 PM   #4
burnin oil
I was going to do this myself. Ended up with power pleather buckets out of a Dodge Durango RT. More comfy and my butt stays behind the wheel. I made some simple brackets for them that reused the factory outer mounts and a couple through the floor in the middle. They take up less room than the bench with only the narrow headrest visable from the back. The best part is that they look somewhat factory. Not like you threw just any old seat in there. No I have enough space to install a blazer console if I wanted. Best part was that they were about $40 each at the local pick and pull. Cheaper than recovering my old bench seat.
burnin oil is offline   Reply With Quote
Old 01-24-2014, 02:22 PM   #5
68gmsee
Active Member
68gmsee's Avatar
I used the rear seat off an 86 Chevy quad cab. I believe it's similar to the front of an 86 single cab. I took the bottom hardware of the seat and had thought about welding or bolting a couple of flat metal sections to the bottom and use my existing runners, but, I was able to just modify them to fit.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
