01-23-2014, 04:15 PM | #1 |
van tilt question
What years will fit our trucks? I found two vans today at the junkyard but dont know what years fit?
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son |
01-23-2014, 04:34 PM | #2 |
Re: van tilt question
IIRC, it's up to '82. Someone will correct that if I'm wrong. Just find one that does not have the ignition switch in the column and you're good to go.
Thank you for your service to our country.
George Morgan Hernando, MS '69 C-10 swb fleetside '72 GMC swb Stepside Last edited by GMan69; 01-23-2014 at 04:37 PM. Reason: spell check |
01-23-2014, 05:03 PM | #3 |
Thank you George, and if thats the cause, one of them would work being it was an 1981 van
01-23-2014, 07:15 PM | #4 |
Thank you for serving Sir. We appreciate that.
01-23-2014, 07:36 PM | #5 |
Thank you for your service to our country, it is great men like you that lets us tinker on these old trucks and travel and do many other thing we take for granted every day. The van tilt is up to 81 and the 82 up to like 89 or maybe a little later has a slick little side marker that fits our trucks and is flush looking and is ten times cleaner than the factory ones. I even use the Torx head screw in the markers they look so much cleaner. Now back to the tilt, Motor homes carry a tilt that look more closely like a truck tilt than the van tilt does and in can be found in motor homes through the 85 model I know of I bought an 85 with a 454 T400 and a tilt that would pass as a truck tilt. There are only slight differences in the way the shifter arm sets and the NSS bolt on in a little different location but very similar. Jim
01-23-2014, 07:55 PM | #6 | |
Moderator
'81 and below are similar but have a longer shaft. '82 and up have keys on the column. You'll need to modify the van tilt by shortening the intermediate shaft. Check this LINK out for your install. Good luck!
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
01-23-2014, 07:59 PM | #7 |
Thank you guys! And thanks Jim, didnt find a motorhome, but I didnt find an 81 and 84. So I guess either one is good. I guess my shifter arm would fit these columns so it looked right. What about the harness? Im guessing mine in the truck would work?
Tommy
01-23-2014, 08:01 PM | #8 | |
01-23-2014, 08:02 PM | #9 |
Not to steal your thread but I have.a similar? Do any of those vans have 3ott? I haven't been able to find one and just wonder if they exist.
-Sterling GIG EM' AGGIES!!!! WHOOOOOOP!!!!! "Whether you think you can or think you can't, you're Right." -Henry Ford 1972 chevy lwb 1934 ford p/u |
01-23-2014, 08:05 PM | #10 |
Only problem I can see is im real picky and the tilt handle wouldnt match being that its out of a van
01-23-2014, 08:26 PM | #11 |
No problem...im gonna say no, I dont think they exist
01-23-2014, 08:38 PM | #12 |
That link that longhorn gave me is very good...but doesnt seem like a real simple easy mod
