01-23-2014, 11:01 PM | #1 |
Help - Pulling Motor and Tranny
Guys I have everything disconnected and tried to pull the motor and tranny tonight. I cannot seem to get the tranny to separate from the transfer case. My questions are:
1. Do I have to drop the transfer case 1st? 2. If not do I take the cross member under the tranny off? 3. I took off the 8 bolts that connect the tranny and transfer, were those the correct ones?? |
01-24-2014, 12:04 AM | #2 |
Moderator
Re: Help - Pulling Motor and Tranny
Hi Posted! I moved this to Engine and Drivetrain for you to get some specialized help. Could someone please help Posted? Thanks
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
01-24-2014, 10:58 AM | #3 |
I work alone and I find that taking the transfer case down first is the easiest for me.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
01-24-2014, 11:12 AM | #4 |
thanks! i thinks so too. Talked to a mechanic today. he said drop the cross member and transfer case. Then take them out.
01-24-2014, 10:04 PM | #5 |
It sucks but that's how i did it...... without a tranny jack, all i had was a little floor jack and a few blocks of wood, not helpful at all, i had to strong arm it down onto my chest then to the driveway, that bugger was heavy! I don't recommend that method..
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
01-24-2014, 10:05 PM | #6 |
I used a motorcycle jack for a tranny jack when I did mine.
01-24-2014, 11:15 PM | #7 |
Everything is out! So pumped!
