07-20-2003, 09:54 AM | #1 |
700R4: First and reverse
are all I have. Transmission will not upshift. It's the stock 85 tranny that has 35k miles on local professional rebuild. I have routinely changed fluid and filter. Fluid is red and does not smell burnt. The TV cable is adjusted properly. There is no hesitation going into drive or reverse from park or neutral.
Someone please tell me it's something simple such as the servo.
350 Crate 10 bolt 3.73 2.5 lift 32x11.50 1904 Edelbrock http://www.oplnk.net/~spirit/K5front.jpg |
07-20-2003, 10:24 AM | #2 |
LED King
In drive or overdrive, does it just not shift like it is in 1st or does it refuse to shift and make noises/vibrations anything strange?
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
07-20-2003, 10:33 AM | #3 |
It simply refuses to shift. No strange noises or vibrations. Ran it all the way up to 4k rpm in od position. When I let off the gas, engine returns to idle. Rev it up again it will still pull in first gear.
07-20-2003, 10:36 AM | #4 |
LED King
I don't think it is a problem with the torque converter or it locking up because is would run rough. Sounds like your tranny simple went south. Sorry.
07-20-2003, 10:41 AM | #5 |
I had the same problem I think your tranny is shot Sorry. You can try going super fast in reverse than foreward I got my gears back for a couple of days doing that. then it had no second at all.
It could possible be some dirt in the valve body. Sorry Dude
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
07-21-2003, 12:01 AM | #6 |
Sounds like you might have a stuck throttle valve or governor. Try winding it up to about 3000 or so and see if it will manual shift out of first and second and so on. You may have also lost all the teeth on your governor gear, that's a common problem with them.
Let me know what you find.
98 Neon 97 Grand Prix GT 02 Grand Prix 40th Anniv. 86 GMC 5.0 77 Olds 98 6.6 REAL AMERICANS, DRIVE AMERICAN |
07-21-2003, 03:49 AM | #7 |
Sounds like bad internal stuff alright..........ie:rebuild time.
Keep us updated. |
07-21-2003, 06:54 AM | #8 |
Talked to the tranny rebuild man. He said broken gears are not uncommon. He, as well as others have advised to leave the old gear, don't worry about it as it will go nowhere and cause no problems, and install the new gear. Everything should be fine. I'll do this within the next couple days and let ya'll know how it turns out.
Too bad I didn't know about this before the expensive tow - 89 miles from home and stranded. I am also wondering how many tranny shops would would be honest enough to simply replace this gear as opposed to charging for a full rebuild! Just a thought, if so these forums have saved me a lot! Thanks everyone maybe I can return the favor by helping someone in the future.
350 Crate 10 bolt 3.73 2.5 lift 32x11.50 1904 Edelbrock http://www.oplnk.net/~spirit/K5front.jpg Last edited by 85 K5; 07-21-2003 at 07:02 AM. |
07-21-2003, 09:48 AM | #9 | |
Gentleman Jim Driver
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
