Old 01-24-2014, 01:16 PM   #1
c10Dream'n
c10Dream'n's Avatar
PROBLEM with Driver Window not wanting to roll up
Took the door panel off my driver side door to see why my window won't roll up, and here is what I'm experiencing.
*as soon as i start to attempt to roll the window up, the door bulges where the window crank is. I can only get a quarter turn out of it and it feels like i might bust the window if I go any further.
Is this a simple fix of just replacing the window crank or do I have a bigger problem? If it's just a window crank I need to order, who should I get it from? Thanks in advance.
Rick
c10Dream'n is offline   Reply With Quote
Old 01-24-2014, 02:02 PM   #2
truckster
truckster's Avatar
Re: PROBLEM with Driver Window not wanting to roll up
You'll probably need to pull the regulator and see if it works when it's out.
I had a similar problem, but it turned out to be the glass binding on really worn window run channel.
truckster is offline   Reply With Quote
Old 01-24-2014, 02:06 PM   #3
c10Dream'n
c10Dream'n's Avatar
so that means the vent window must come out AGAIN, that sure was a pain when putting my new ones in. then take out the door glass as well. gonna need some patience when I attemp this task.
Old 01-24-2014, 02:25 PM   #4
burnin oil
Could also be the third guide wheel. Before I replaced the regulator I had the same basic problem. The wheel broke off and the guide would jump off track and get bound up.
burnin oil is offline   Reply With Quote
Old 01-24-2014, 02:48 PM   #5
WIDESIDE72
WIDESIDE72's Avatar
If a roller breaks the flat spot it creates wedges its self into the track.
As far as window installation, it used to give me fits too til i figured it out.
1. Remove bolts at bottom of rear glass guide.
2. Loosely install regulator in door with 2 bolts
3. Crank window regulator all the way up til rollers stick up through opening.
4. Slide glass channel onto rollers from outside truck
5. Crank window down and install remainder of all attachment bolts loosely.
6. Roll window up and down to ensure it doesnt bind
7. Tighten bolts
Note: I have never done this with the horizontal window felts/ rubbers installed. I pit them in last.
WIDESIDE72 is offline   Reply With Quote
Old 01-24-2014, 03:05 PM   #6
burnin oil
Sounds like a good plan. 100% wont work with the channel felt in there. Do you loosen up the vent window? Mine wont clear the regulator and did I ever try.
Old 01-24-2014, 04:30 PM   #7
WIDESIDE72
WIDESIDE72's Avatar
Sorry. I forgot to include that the vent window assay has to be out. It goes in last.
Old 01-25-2014, 01:30 AM   #8
R.L.
R.L.'s Avatar
I had a problem with my window sticking when rolled all the way up, broke a couple Auto zone window cranks rolling the thing down after installing new window felt. The inside track just below the door lock wasn't exactly lined up with the track on the back/ outside top of the door. I cut about 6" of the felt off and the problem went away. When up the window sits in enough felt so that it doesn't rattle when down the glass doesn't contact that area of channel any way just don't take any above the bottom of the window seal so theirs no air leak.
R.L. is offline   Reply With Quote
Old 01-25-2014, 11:51 AM   #9
67swb72klb
67swb72klb's Avatar
you cant put too much lube on the spring and all the rest of the moving parts
that spring will bind things up and like RL said the rear guide on the window can use some lube too
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 01-25-2014, 12:00 PM   #10
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I also find that the window felts bind up.I took some clear silicone lube(Remember foosball rod lube?) and sprayed the felt.That helped my windows a lot.If you have new felts in there,try it.Always go for the low hanging fruit first.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 01-26-2014, 01:18 PM   #11
c10Dream'n
c10Dream'n's Avatar
Thanks for the feedback to all, I will give these a shot one at a time.
