Old 01-24-2014, 01:56 PM   #1
CC69Rat
CC69Rat's Avatar
Converting a Non-AC cab to AC
I bought an AC dash from Randy to convert my 68. What's the easiest way to get the original one out and put in the AC dash? I really dont want to cut around the lower windshield area unless I have to, .. are those just spot welds in that area or would I need a plasma cutter ? I've just never done it.
I have heard people will just cut it on the dashes underneath where the dash pad goes and weld it in there, re-using the old tabs to weld it back in. What would you guys suggest? Thanks.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 01-24-2014, 02:07 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Converting a Non-AC cab to AC
Like you said in the second paragraph is what I believe is going to be the best way to go if you really want to replace the dash. I have seen someone try to remove the spot welds and it was a mess. Windshield had to be removed and wound up having to replace it and the rubber (accidently broke it).
Personally, if I install a/c in my non a/c 68 GMC I'm going with the under dash a/c vents rather than cut the dash. Also, I have seen some where guys cut their own openings with supplied instructions by manufacturers of aftermarket a/c units. That would be a better option than cutting out the dash.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 01-24-2014, 02:50 PM   #3
WIDESIDE72
WIDESIDE72's Avatar
I would think it would be easier to cut the dash vent openings into the existing dash, unless there is other damage to your dash. Just an FYI, youll need to modify the firewall as well if you are going to install factory ac. Search the forum as i have seen it covered a few times.
WIDESIDE72 is offline   Reply With Quote
Old 01-24-2014, 04:01 PM   #4
teeitup
Just like to part out trucks!!
teeitup's Avatar
Chad, if you cut your dash under the dash pad and do the same to the Ac dash your getting from me and weld it back in, thats the easiest way, and as Steve said you'll have to get a section of firewall. If you look at my thread on parts board about parting a cab, there is a guy who had me cut the firewall section out for him, thats the piece you'll need
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 01-24-2014, 04:36 PM   #5
CC69Rat
CC69Rat's Avatar
I had just planned on doing a Vintage air under dash kit and use the factory vents. Not going to work ?
Chad
Old 01-24-2014, 04:54 PM   #6
WIDESIDE72
WIDESIDE72's Avatar
That should work. Its what i have planned on my step side. Im just going to cut the dash thats in it now though. You only have to do the firewall surgery if you are going to install factory ac in a non factory ac cab.
Old 01-24-2014, 05:03 PM   #7
CC69Rat
CC69Rat's Avatar
Yeah I have a BB in mine and didn't really want to use the factory firewall box anyway .. whew I can handle the dash part I just dont want to get into cutting the firewall and stuff. It's a super clean cab (bare) and I guess I could cut the bottom of the windshield chanel I just thought Id go as far as under the dash pad, weld it in there and grind the welds where they look ok (not worry about ti a whole lot) and let the dash pad take care of the rest.
Thanks for your help fellas. Randy, if you want to cut the dash off leaving the top edge of those tabs under the dash pad that will be cool with me too. It might make it easier and cheaper for you to ship. I wont be using the top section of the dash anyway just leave me enough to get it welded back in under the pad.
If you have shipped it already that's cool too.
Chad
Old 01-24-2014, 05:12 PM   #8
mcbassin
Still Learning
mcbassin's Avatar
It's really not that bad to drill out the spotwelds and change the whole dash. Just use a flat angled drill (smallest dia. you can get away with) at the pinch where the windshield rubber sits. I have done it and it worked great on my 67.
Sounds like you have it figured out already though. I never thought about cutting down that seam where the dashpad mounts.
mcbassin is offline   Reply With Quote
Old 01-24-2014, 06:10 PM   #9
jmader
jmader's Avatar
Not trying to hijack the thread but one other thing I can't seem to find addressed in other threads is what is the best technique to cut the holes out of an existing dash? It looks like a hole saw would do the trick for the outers but the middle one has me a little nervous.
1949 Chevy 3100 Five Window
1964 Chevy C10 Lambrecht Auction project
1967 Chevy SWB K10
1967 GMC K15 Project
Build thread-
http://67-72chevytrucks.com/vboard/s...72#post6502772
1968 Chevy Anniversary K10
1991 K5 4" Lift 35's (the wife's toy)
jmader is offline   Reply With Quote
Old 01-24-2014, 06:27 PM   #10
motorcritter
motorcritter's Avatar
I saw on a thread about A/C install, and they used body panel adhesive to install the replacement A/C dash- that had been removed by drilling out the spot welds. Saves a lot of headache for the job, less chance heat damage, access problems, etc.
If 'that which does not kill me, makes me stronger', then I should be Superman by now!
motorcritter is offline   Reply With Quote
Old 01-24-2014, 07:52 PM   #11
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
I always take my template and drill holes in the corners then use a body saw to cut them out.. It's like a jig saw but a air tool for cutting sheet metal..
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 01-24-2014, 09:34 PM   #12
olrosa
olrosa's Avatar
What screamingchevy said
olrosa is offline   Reply With Quote
