Old 01-25-2014, 07:18 AM   #1
72freak
Rottenwood Garage Member
72freak's Avatar
Disc brake swap, now no brakes? Pedal to the floor when truck is turned on.
We have done brakes on 100's of vehicles here at Rottenwood Garage so I am fairly certain I have the procedure down. LOL. HOWEVER, we are having trouble with a 69 C10 2x4 that we just converted from power drums to front disc. The kit he ordered came from Brothers with all the brake components, spindles and the prop valve. We used the booster I had put on the truck when I converted it to power drums a few years ago and it works fine. We bought a 72 disc brake master cylinder to complete the system. Its all together, no leaks, bled out with no air in the lines and the rear brakes are weak and when you turn the truck on so the booster is working the pedal goes to the floor. We bleed it out while not running and end up with a solid pedal but as soon as you start the truck it goes to the floor and at that point there is no rear brakes and the front seem to grab a little. We did bench bleed the master and all of the flexible hoses and rear brake components are newer..We are stumped. We are going to put a fresh set of eyes on it this morning when all the guys come over so we may get it figured out but I wanted to see if any of you have had the same experience and what was your solution..
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 01-25-2014, 10:25 AM   #2
panhandler62
Java Mechanic
panhandler62's Avatar
Re: Disc brake swap, now no brakes? Pedal to the floor when truck is turned on.
Do you have the correct actuating arm in the booster for the new master cylinder?
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 01-25-2014, 05:41 PM   #3
72freak
72freak's Avatar
I will check that out. I will measure the depth of the 2 different masters and see if they are different. Good thing to check.
Old 01-30-2014, 10:05 AM   #4
72freak
72freak's Avatar
Thanks for all the ideas. We figured it out.
Old 01-30-2014, 10:08 AM   #5
earl84
Inquiring minds want to know, what was the issue, and how did you fix it?
earl84 is offline   Reply With Quote
Old 01-30-2014, 11:28 AM   #6
72freak
72freak's Avatar
We all stepped back and let one man check the work of 5 people. Turned out the person who installed the front brake calipers was also the one who was in charge of bleeding the front brake calipers. FYI, if the calipers are on the wrong side with the bleeder screws pointed down, you wont get the system free of air.
Old 01-30-2014, 02:28 PM   #7
panhandler62
Java Mechanic
That'll do it.
Keith
Old 01-30-2014, 03:06 PM   #8
whitedog76
I'm hoping that guys is someone's kid or an apprentice.
whitedog76 is offline   Reply With Quote
Old 01-31-2014, 07:45 AM   #9
72freak
72freak's Avatar
Mistakes happen. I'm sure the most experienced mechanics make them too.
I actually did the same thing with my F550 last year. The boxes were marked left and right but I didn't know there was a front of caliper or rear of caliper option and it was not listed as an option.. I mounted them correctly according to the box. I did figure it out once I started to bleed though.
Old 01-31-2014, 08:20 AM   #10
panhandler62
Java Mechanic
You show me someone not making mistakes and I'll show you someone not doing any work.
Keith
