cab swap
i was wondering what the easiest way to move a cab from one frame to another would be. any suggestions? thanks
chevelito
the obvious answer is 4-5 big guys and a case of beer
New deadline...when my son can drive. ![]() Aloha from Honolulu, HI |
its all about the +6 inches
Agreed...however, cab first...beer last.
#4 | |
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
thanks for the suggestion, i tried with 4 guys but couldnt get it. i ended up using a floor jack, cinder blocks and some angle iron and pulling the old frame out from under it. thanks again for the help.
Wow... never heard of one being that stuck.
chevelito
wow, I had my 3 cousins and I lift the cab with no problem. still got the doors and interior in there?
jay
yeah, all interior and dash was still in, fuel tank was still in, and doors were still on.
that pretty much doubles the 500 or so pounds you were trying to lift.
