Old 01-25-2014, 02:32 PM   #1
oski6754
oski6754's Avatar
Max tire size on stock height Sub?
I am buying a 72 Sub 1500 4x4 and wanted some guidance on what the max tire size is that can fit without rubbing etc. I've had Jimmy's/Blazers that would fit 33"s at stock height, but figured I should ask the experts.
oski6754 is offline   Reply With Quote
Old 01-25-2014, 02:49 PM   #2
dougo
dougo's Avatar
Re: Max tire size on stock height Sub?
What wheels are you running? Offset might come into play.... But I'm running 33s with a 3ish (maybe 4) inch lift - no rubbing (with my steelies). BUT, mine had Weld wheels on it when I bought it... Passenger front rubbed a little with 33s with the Weld wheels.
I cannot say for stock height.
Doug
'72 GMC K2500 Suburban 4x4
dougo is offline   Reply With Quote
Old 01-25-2014, 03:01 PM   #3
oski6754
oski6754's Avatar
I believe they are 15x8 steel wheels.
Old 01-25-2014, 09:56 PM   #4
jaywashburn
For a stock height K10 with 15X8 steelies you should be able to run 31X10.5x15 tires without them rubbing. You would probably be okay with 32X11.5X15 also.
jaywashburn is offline   Reply With Quote
Old 02-02-2014, 07:01 AM   #5
olblue60@aol.com
member
I had a 72 Custom Deluxe Suburban with 3 rows of seats. They usually have more rear leaf springs in the trucks with the third seat. I ran stock size 31 10.50 15's on stock steel wheels, but I will probably upgrade to some 32 11.50 15's that I have because they look a little bit lost in the wells.
1967 C/K10 Chevy Panel
1968 C/K20 Chevy Pickup
1968 C/K10 Chevy Suburban
1941 Chevy Sedan Delivery
1960 Chevy Sedan Delivery
1972 Camaro SS 396 #s matching
1971 Harley FX Superglide
olblue60@aol.com is offline   Reply With Quote
