Old 01-25-2014, 09:18 PM   #1
dave666693
dave666693's Avatar
weird T case noise help
I have a NP205 mated to a TH350. I put the tranny and T case in assuming everything was good, but I had no history. When I let off the gas in 2 wheel drive it sounds like the t case or tranny is real sloppy like a gear is loose. Only does it once in a while. Anyone ever heard this? My plan is to drop the t case, possibly rebuild, but I wanted some input 1st. New rear driveline, no obvious loose or bad parts. Thanks, Dave
67 C20/
68 C10 stepside/inline 250--current project
71 GMC 4x4
70 Blazer project-Zombie assault vehicle
67 4x4 Burb
dave666693 is offline   Reply With Quote
Old 01-25-2014, 10:35 PM   #2
ryanroo
ryanroo's Avatar
Re: weird T case noise help
The did shaft that connects the output of the transmission to the input of the transfer case can wear out over time and allow some slop. That may be your issue, or some of it. The spud shaft is in the adapter between the transfer case and the transmission.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 01-25-2014, 10:41 PM   #3
dave666693
dave666693's Avatar
I think the adapter seals are bad so it will be looked at too
67 C20/
71 GMC 4x4
67 4x4 Burb
Old 01-26-2014, 02:45 AM   #4
swamp rat
swamp rat's Avatar
If your gonna pull the driveshaft check the backlash on the pinion while your there.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-26-2014, 10:14 AM   #5
Orange Crate
Orange Crate's Avatar
Here are a couple of links to info for a rebuild if you need it.
http://www.quad4x4.com/New_Process_NP205_Parts.html
http://www.akfabshop.com/alaskaoffroad/tech_2.htm
Also the pic shows an old adapter shaft with the bearing and the box is the part number for a new shaft that eliminates the bearing (not needed). If you zoom into the pic the old build up shows the bearing in place. A new adapter shaft will be machined straight across except for the snap ring groove. The trans to T-case adapter is the weak link, the seals will allow transmission fluid to transfer into the T-case and conveniently fill it up for you (this is why I replaced the adapter shaft, the seals had worn grooves into it)....this doesn't make any noise though, until you find this out and start swearing...!
X2 on the pinion check.....
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed
Orange Crate is offline   Reply With Quote
Old 01-26-2014, 01:46 PM   #6
dave666693
dave666693's Avatar
I have another NP 205 but not sure what tranny it was mated to. Is there any differance? I am guessing the adapter is diferrant.
67 C20/
71 GMC 4x4
67 4x4 Burb
Old 01-26-2014, 04:01 PM   #7
Zane M
Adapter and spline count would be the major differences, depending on what it was behind.
Zane M is offline   Reply With Quote
Old 01-26-2014, 05:33 PM   #8
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
I agree with Ryan, the slop could very well be in the adapter between the trans and tcase. Another item that causes a lot of slop and racket on a 205 on decel is a loose idler shaft. A couple 205s ago I had a horrendous noise and vibration on a light coast and after ripping into it the idler was so loose you could grab it and actually shake it around. Surprisingly the bearings were still good and it just needed the big nut tightened up.
DirtyLarry is offline   Reply With Quote
Old 01-26-2014, 08:55 PM   #9
dave666693
dave666693's Avatar
started pulling it apart today. T case is definately full of tranny fluid. Didn't feel anything wrong with the pinion shaft.
67 C20/
71 GMC 4x4
67 4x4 Burb
Old 01-30-2014, 04:18 PM   #10
doubleclucker
doubleclucker's Avatar
GM NP205 -input face racetrack(bathtub)8 bolt pattern with input gear-
/short female 32 spline
/male 10 spline
/male 27 spline
-input face round 6 bolt with-
/long female 32 spline
100:1 low gear!
doubleclucker is offline   Reply With Quote
