Old 01-26-2014, 09:18 AM   #1
THE BOSS
moving gas tank?
I plan on removing the tank from behind the seat and building a speaker box for that area.
question, I believe the Blazer 22 gallon tank will fit right in my frame above behind the axle?
where is the best place to buy it, I will need mounting hardware, tank unit......
where is the best place for the filler neck? First thought was to copy the Blazer.
Thanks.
Proud 72 C20 4WD lots of lift and big tires.
THE BOSS is offline   Reply With Quote
Old 01-26-2014, 09:30 AM   #2
Hugh Mongus
Re: moving gas tank?
http://www.powerblocktv.com/episodes...ls-engine-swap
Hugh Mongus is offline   Reply With Quote
Old 01-26-2014, 10:10 AM   #3
THE BOSS
thanks and interesting!
I take it the Suburban tank bolts to the frame with not straps?
Old 01-26-2014, 03:39 PM   #4
68'CTown
68'CTown's Avatar
I moved my tank to under the frame and I used the 68 camaro gas tank and did a flip down license plate.
Here is a link of what I did.
http://67-72chevytrucks.com/vboard/s...d.php?t=611812
http://67-72chevytrucks.com/vboard/s...d.php?t=607311
Thanks!
Craig
- Every day is a new opportunity. You can build on yesterday's success or put its failures behind and start over again. That's the way life is!
68'CTown is offline   Reply With Quote
