01-26-2014, 11:25 AM | #1 |
Opinions on my cab
Based on these pictures alone, would you say the rust repair would be too much work to be worth it?
01-26-2014, 11:39 AM | #2 |
Re: Opinions on my cab
Unfortunately I would have to say it would be too much to try and work with. It looks like someone put some sort of coating on the roof so you may be in for more surprises down the road.
Gary Slowly looking for my next 67-72 truck |
01-26-2014, 11:48 AM | #3 |
I am a Referee of life.
If the rockers and floor are in the same condition,you'll be better off with a different cab.If nothing else needs replacement,you may be able to find a roof for reasonable.The real deal here is to look at what needs to be done to your cab and determine if it's cheaper to replace than to repair.I would much rather do rockers and floors than to try to do a new roof myself but you have a better handle on your skill level.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
01-26-2014, 11:48 AM | #4 |
Yeah its some sort of foil colored sticky on stuff. I Figured a new roof panel from LMC or the like would solve that and a new drip rail and some small patching would be doable but I dont know anything about it.
01-26-2014, 11:50 AM | #5 |
The floors are good, the rockers aren't horrible but I would eventually replace them, also the cab corners and cab supports would need replacing one of these days
01-26-2014, 12:00 PM | #6 |
that's a lot of work (and $) I would look for a cab or parts truck
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
01-26-2014, 12:02 PM | #7 |
Any leads on where to look for cabs? Just craiglist every city? Theres no junk yards around here so I'll end up having to buy from out of town
01-26-2014, 12:02 PM | #8 |
Roadtrip!
I would replace the whole cab unless the floors are really nice, than i would get another roof off a donor truck.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
01-26-2014, 12:05 PM | #9 |
I wouldn't touch that mess with patch panels, that's a candidate for an entire roof swap (pillars and all) or new cab.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
01-26-2014, 12:11 PM | #10 |
searchtempest.com put in what you are looking for and how far you are willing to travel searches craigslist for you.
01-26-2014, 08:21 PM | #11 |
I'll just do some fiberglass Band-Aids til I can locate/afford a new cab.
Hey is it normal to feel like the truck is lightly braking when you let off the gas to coast? I'm assuming its normal since its only 3 speed |
01-27-2014, 12:02 AM | #12 |
If you're going over 50-55 mph, yeah, unfortunately that is normal. You probably have a 3.73 rear end, and with the 3spd with 1:1 gear ratio, 3.73 or maybe 4.11 rear end, crappy aerodynamics, when you let off the gas these big beasts slow right down. Check your gear ratio. A 3.08 (higher gear, lower RPMS) can help alleviate that some without the added $$$ of swapping to an Overdrive trans.
01-27-2014, 12:17 AM | #13 |
Thanks I'm fine with it as is just wanted to make sure it was typical
01-27-2014, 12:35 AM | #14 |
All the rain is going down the A pillar also so that will get ugly when you start digging.
01-27-2014, 09:23 AM | #15 |
Florida Edition
Yep, time for a cab swap. What year are you looking for?
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
01-27-2014, 10:27 PM | #16 |
Convertible top maybe? That's a lot of rust repair, and in the long run you'd spend more in body work than you would for a new cab( or truck for that matter) I did a top replacement like that before both a pillers, doors, trim molding and 1500$ later it still fit like crap. Don't mean to be a downer on your project but you'll be much happier with a new cab.
-Sterling GIG EM' AGGIES!!!! WHOOOOOOP!!!!! "Whether you think you can or think you can't, you're Right." -Henry Ford 1972 chevy lwb 1934 ford p/u |
01-28-2014, 04:29 AM | #17 |
I started out with what I thought was a pretty solid cab but when it cameack from blasting I found out that someone had done a fiberglass patch job in several places including a place on the roof line just above the windshield. I showed the cab to several body men and they all said it was not bad at all. Being on a very tight budget I have no choice but to do the work myself but soon realized it was more than my skill could handle. After looking at yours I would say it is way to far gone to even attempt repairing. U will be time and money ahead to find another cab. I can send u pics of mine to give u an idea of the repair and what the pros say is not bad at all if you like. Pm me a cell number or email and I will get u some pics
01-28-2014, 08:22 AM | #18 |
Jb70c10
What part of tx are you in? I know some good body men depending on your area that don't charge out the a$$ for patch panels. Then you just finish off the rest of the bodywork save some cash that way. -sterling
01-28-2014, 01:21 PM | #19 |
Union welder, pm sent
