Old 01-26-2014, 05:22 PM   #1
DreamRyder1963
DreamRyder1963's Avatar
Smoke Under Load
The past couple of weeks I have noticed smoke coming out of my exhaust will I'm accelerating quickly (half to full throttle). I think I might be burning some oil under these conditions. The smoke is white with a little pale blue. Short of rebuilding the engine is there anything I can do to fix this? Is it possible that oil is just getting past the valves under higher rpms?
1971 Chevy C10 Cheyenne (sold for Mazda)
1963 Chevy Corvair Pro-Touring Project
2012 Mazda 3 i Sport sedan
http://www.dracoautodesigns.com/
DreamRyder1963 is offline   Reply With Quote
Old 01-26-2014, 05:43 PM   #2
Carl Spangler
Carl Spangler's Avatar
Re: Smoke Under Load
There are a lot of "mystery" products that claim to free "stuck rings":
GM Top Engine Cleaner, Marvel Mystery oil, Seafoam, etc.
Do a web search and you'll find a couple more aggressive methods which typically involve pouring some sort of solvent into each cylinder.
I recently used Seafoam in the oil and fuel for a new to me 71 SWB and I can't say anything negative about it. I ran a can through it just as a WTF lets see what this stuff does. The old 6 seems to run fine after the 'treatment'.
cheers
JohnG
Carl Spangler is offline   Reply With Quote
Old 01-26-2014, 05:54 PM   #3
DreamRyder1963
I know seafoam does want it claims at lest of the carbon removal side of things. I might try it on my next oil change. I am wondering since it only does it when I hop on it (not every time either) if I should just keep an eye on my oil levels.
Old 01-26-2014, 05:57 PM   #4
bob8619
The smoke is while accelerating or after you let your foot off?
bob8619 is offline   Reply With Quote
Old 01-26-2014, 06:04 PM   #5
DreamRyder1963
The smoke is while accelerating. If I lift off the smoke stops.
Old 01-26-2014, 06:10 PM   #6
Longhorn 70
Longhorn 70's Avatar
White smoke is usually ATF or water (steam). If you have a TH350 or TH400 it could be a leaking vacuum modulator on the transmission.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 01-26-2014, 06:14 PM   #7
DreamRyder1963
Its a three speed. When we installed the headers a couple of days ago, we found that the dip stick is way loose. Could this be causing it?
Old 01-26-2014, 07:23 PM   #8
dubds10
Stalker Nate
Had the same thing happen to my 350/350 but only when I'm stompin on it and doing 80-90mph. Don't find it when I stomp on it at low speeds. Figure just oil working it's way to where it shouldn't be lol I think my 350 needs a little rebuild though as it feels tired.
1957 GMC SWB stepper modified summer time driver
1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project
1965 Chevy P10 Ice Cream Truck project
Instagram - TheDonutDiner
FaceBook - @UscreamIscream
dubds10 is offline   Reply With Quote
Old 01-26-2014, 08:09 PM   #9
Longhorn 70
I guess that rules out the modulator. Check the PCV valve too. If they are clogged or the line leaks it can cause this. Does the engine have a lot of blow by? Pull the oil filler cap and rev the engine. Put your hand over where the cap goes. Do you feel pressure??
Old 01-27-2014, 12:03 AM   #10
DreamRyder1963
I think I have a small leak where the hose from the pcv attaches to the carb. Oil slowly puddles on the intake directly below the hose.
Old 01-27-2014, 12:38 AM   #11
swamp rat
swamp rat's Avatar
I believe that would suggest ring blow by, time to run a compression test, first dry and record all cyl's, then add a squirt or two of oil one cyl at a time and check again, if the compression goes up it points to bad rings, if it stays the same it points to bad valves, timing chain ect.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-27-2014, 10:46 AM   #12
DreamRyder1963
I tried revving the engine will sitting still but nothing happened. I believe the leak at the pcv is due to an ill fitting hose but I will try the compression test. If it is ring blow by what are my options.
Old 01-27-2014, 10:53 AM   #13
geezer#99
geezer#99's Avatar
Two questions.
How many miles do you travel between oil changes?
How much oil do you use between oil changes?
geezer#99 is online now   Reply With Quote
Old 01-27-2014, 11:00 AM   #14
DreamRyder1963
I have only had the truck long enough to change the oil once. I need to due it again. It uses about a quart a month but I think I have a leaking oil pan.
Old 01-27-2014, 11:04 AM   #15
geezer#99
geezer#99's Avatar
Let's rephrase that.
So how far do you drive in a month?
Old 01-27-2014, 11:57 AM   #16
DreamRyder1963
Around 1200 miles a month
Old 01-27-2014, 12:10 PM   #17
zeldman
zeldman's Avatar
Another possibly is worn valve guides or valve seals. The old rubber mushroom valve seals are known to dry out and get hard and let a little oil get into the cylinder.
2005 GMC K2500HD D/A
1993 GMC K1500
2011 Subaru Legacy.
2013 Subaru Outback
1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot.
zeldman is offline   Reply With Quote
Old 01-27-2014, 12:12 PM   #18
geezer#99
geezer#99's Avatar
One drop of oil leaked every 100 feet equals one quart of oil every 1000 miles.
Which means if your motor was leak free you'd go about 2200 miles on a quart.
I don't think there's anything wrong with your rings or valve seals.
If you rev it standing still and see no smoke just keep driving it. Fix the leaks.
You're likely showing a little smoke from the oil burning on your pipes.
Old 01-27-2014, 09:07 PM   #19
mrolds88
I dont know about the other products, but the GM Top Engine Cleaner REALLY needs to be used outside.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 01-27-2014, 09:41 PM   #20
hugger6933
If your leak is due to blow by or your losing compression due to the blow by the options you asked about are pretty limited to a freshen up of the cylinders by either replacing the rings or the pistons and rings depending upon the situation and how drastic it is once you get inside it. If it is running pretty good otherwise, most likely you will just need to rering it with some fresh bearing and gaskets and a valve job and have a really decent motor, but you have to be careful these days cause the crate motor prices can be cheaper than building your own if too much work has to be done. Unless it is a matching number motor or something like that you may need to do a line item comparo just to keep an eye on the pennies. Jim
hugger6933 is offline   Reply With Quote
Old 01-27-2014, 09:59 PM   #21
DreamRyder1963
The engine is very strong. I checked the oil today and its still full so I can't be losing it very quickly. I will problaly throw a can of seafoam in it right before I change the oil pan out but besides that I will just seal the leaks and keep an eye on it.
Old 03-10-2014, 04:48 PM   #22
DreamRyder1963
I wanted to give everyone an update. I didn't notice a change with the seafoam but I adjusted the valves and now it doesn't smoke. Some. Of the valves were very loose so I guess that was the problem all along.
