01-26-2014, 10:25 PM | #1 |
vent window question
I would like to hear your guys opinions on the vent window seals. Where can I get some seals that will fit really good and does anyone have any advice to putting in the new felt division bar liner so that it looks good.
01-26-2014, 10:36 PM | #2 |
I am a Referee of life.
Re: vent window question
I can't help on the seals but the division bar was pretty easy to get to look right.I drilled the riverts from the old one.Then I matched the hole to the new one.I had to drill them a slightly larger size because I couldn't find the smaller rivets.I used pop rivets but the anvil of the rivet gun wouldn't fit into the division bar.I cut a short piece of copper tubing and put it over the rod of the rivet then put the rivet into the division bar and got it as tight as I could.Then pumped the handle on the rivet gun.The division bar has stayed put for over ten years.I also recommend using some lube(I use silicone like for foosball bars) on the felt in the channel.It seems to help the felt smooth out and work in.Make sure you have the division bar tight in the channel on every rivet.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
01-27-2014, 12:21 AM | #3 |
Thanks I definitely need to get a rivet gun or something.
01-27-2014, 12:24 AM | #4 |
Moderator
I used Precision brand on my rebuild. They worked well.
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
01-27-2014, 02:27 AM | #5 |
Moderator
X2. They fit like a glove. GMCPaul and Classicheartbeat carry them.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
01-27-2014, 02:33 AM | #6 |
Moderator
I did this as well, except I used a bench grinder to shave down the anvil so it would fit in the channel
01-27-2014, 10:51 AM | #7 |
Also make absolutely sure you have the rivet seated all the way to the bottom of the channel and that the head is flat against the bottom of said channel.
01-27-2014, 03:50 PM | #8 |
Willie Swamp Angel Truckers '72 C10 Highlander People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. |
