01-27-2014, 01:47 AM | #1 |
Headers For A 74 4x4 Big Block 4 speed
Who sells a good header for a 1974 4x4 with a 4 speed transmission and a big inch big block?
01-27-2014, 09:46 PM | #2 |
Re: Headers For A 74 4x4 Big Block 4 speed
I used big block 73-87 2wd headers on my 74 with a 4 speed they fit excellent but they do hang down a bit lower than they need to but its not a problem.
01-27-2014, 09:55 PM | #3 |
Are you having any issues with the oil filter clearance? And is your truck the 4x4 in your avator?
01-27-2014, 10:05 PM | #4 |
Yes they are on the truck in my avator. The only clearance problem is the collector is right beside the leaf spring-shackle bolt. It hits when the motor torques. Other than that that they fit perfectly. Lots of clearance for plug wires and oil filter. I have had 2 sets of headers on this truck and they were both the 2wd headers and both fit the same. I can get some pictures of the fitment if you want.
01-28-2014, 09:17 PM | #5 |
I had a set of headers on this truck but can't find them.The exhaust is set up for a small block and a big block.It has 4 flanges instead of 2 and a short section of pipe.
I was running a 400 in it and also a 454 and I had to run down to the muffler shop so many times I had the guy build me a pair of pipes. I tried looking them up online and couldn't find much for a 4x4 with a 4speed.I appreciate your help. |
