Old 01-27-2014, 02:00 AM   #1
First c10
First c10's Avatar
Tow haul button??
Has anyone used the tow haul mode as performance mode on a gen IV 6l80?
And
Has anyone used the Speartech tap shift harness or something like it?
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 01-27-2014, 03:19 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Tow haul button??
If you use the "search this forum" instead of the search at the top, you'll get a couple of good results on the topic.
A few have used it off the "stalk" and others just run it as a push button. I believe Hart Rod has Tow/Haul working on his, some others do as well.
I don't know anything about that particular speartech part, but some folks have used something similar or used another setup to run the TuTd off of the 6l80e-cars.
You might find a touch more on setting it up over on Ls1tech
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-27-2014, 05:02 AM   #3
Andy4639
Old member
Andy4639's Avatar
Talking Re: Tow haul button??
I'm going to see if Hawks will set mine up like this.
Just in case I want to pull my dragster cart with the truck again.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-31-2014, 03:38 PM   #4
Hart_Rod
Hart_Rod's Avatar
And
I'm not sure how you would initiate this with the tow/haul mode toggle switch, as it has nothing to do with TUTD function. The gear selection controls this ("M" mode).
For the Camaro/Corvette 6L80s, if you go into the "M" mode, you are in what the owners manual calls the "sport" mode. In the "sport" mode, some torque management is reduced and the shifts are a lot "sportier". Also, in this mode, you can use TUTD (if you have the correct wiring and hardware....paddle shifters or toggle button).
And, I think, you have to use a BCM to use the tow/haul function anyway, at least that's how I think it works for the truck 6L80s/90s. With that all being said, a tuner that knows what he is doing, should be able to program the "M" selector position in a truck transmission to have a "sportier" mode, because that capability exists in the Tuning software that is out there (HPTuners/EFI Live).
Clear as mud???? :LOL:, ask me how the paddle shifters work and I'll write you another book......
Hart_Rod is offline   Reply With Quote
Old 01-31-2014, 04:18 PM   #5
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
I actually am interested how the paddle shifters work...
chevyguy_72 is offline   Reply With Quote
Old 01-31-2014, 04:38 PM   #6
First c10
First c10's Avatar
I had read somewhere how someone used the tow haul button as a performance tune button. but cant remember where. The TU/TD speartech has, i was wondering how it worked? do you have to change some wiring or anything? change the ECM setup? etc?
GO GO!!!
Old 01-31-2014, 06:43 PM   #7
Hart_Rod
Hart_Rod's Avatar
I purchased a Shriftersix setup. It came with billet aluminum wireless paddle setup and a wireless receiver. the receiver plugged into some wires that John at Speartech pulled from the ECM when he built my harness. I sent the receiver to John and he verified that it worked when plugged into the harness. They work great, but are not cheap. Speartech sells a module with a toggle switch that will allow you to use the TUTD feature that is a lot cheaper.
I've heard of guys doing the tow haul thing you are talking about on 4L80/60s, but not on the A6's (doesn't mean it can't be done). The TUTD module uses different resistors to make the transmission changes gears up or down. A wire has to be pulled from the ECM and then plugged into Speartech's module or some paddle shifter setup. I think there are a couple of things that have to be setup in the computer if it the transmission is not a camaro/corvette, but I'm not 100% sure what it is. You will need to go on LS1tech or download a truck and car tune and do some comparisons.
Old 02-02-2014, 12:17 PM   #8
First c10
First c10's Avatar
Ok great thanks
GO GO!!!
Old 02-02-2014, 12:46 PM   #9
Hart_Rod
Hart_Rod's Avatar
Ok great thanks
I found a couple of threads on LS1Tech that discuss the tow/haul for A4's:
http://ls1tech.com/forums/pcm-diagno...ble-tunes.html
http://ls1tech.com/forums/pcm-diagno...e-my-swap.html
http://ls1tech.com/forums/multimedia...-my-fbody.html
http://ls1tech.com/forums/conversion...m-not-bcm.html
Old 02-02-2014, 01:12 PM   #10
First c10
First c10's Avatar
Wow now that's some information overload!!! Thanks hart rod.
GO GO!!!
