Old 01-27-2014, 10:36 AM   #1
Houston Ben
Houston Ben's Avatar
Rear disk brake conversion on Power nation
Hey,
I was watching Power Nation/Detroit Muscle yesterday and they converted to rear disk on a TA 10 bolt 8.5 by using the brake backing plate from a 98-02 Camaro with a 1/8" spacer, Has anyone done this with the truck 10 bolt?
http://www.powernationtv.com/episode...t-differential
Houston Ben is offline   Reply With Quote
Old 01-27-2014, 08:39 PM   #2
LONGHAIR
Re: Rear disk brake conversion on Power nation
I would doubt that the bolt pattern of the backing plate is the same?
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 01-28-2014, 02:22 AM   #3
66 C10 383
I've got a 2000 Camaro rear disc setup that was going on a previous project that got sold. Been thinking about swapping them to my 66. I'm pretty sure it's not a direct bolt on as said above. However, Moser Engineering makes a housing end that will fit the axle tubes so that it can bolt on. You also gain the Ford style bearing retention so you also don't have to worry about breaking a c-clip on the axles.
This is all "in theory" of course as I haven't done it yet myself ...
Doug
Old Build Thread - 383/T56
http://www.67-72chevytrucks.com/vboa...d.php?t=540838
Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua
5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital
http://67-72chevytrucks.com/vboard/s...d.php?t=778784
66 C10 383 is offline   Reply With Quote
