01-27-2014, 01:01 PM | #1 |
2003 Z71 Dropping Transmission Pan
I have an 03 Silverado K1500 Z71. It recently turned 100k miles, so I decided to change the transmission oil/filter. The problem is to get the pan off their is the shift cable bracket in the way. It is mounted to the transmission with 2 T40 torx head screws. They are siezed pretty well. Using a 3/8 drive ratchet wouldn't budge them. Yesterday I sprayed PB Blaster (the best I could) just to start soaking them, hoping over time they would free that way.
Any advice? Have you ever run into this issue?
Robert 1965 Chevy C10 http://67-72chevytrucks.com/vboard/s...d.php?t=374373 1997 Chevy K2500 6.5 diesel |
01-27-2014, 03:55 PM | #2 |
Re: 2003 Z71 Dropping Transmission Pan
I usually use a pry bar and bend it over until it hits the driveshaft. That will give you enough room to wiggle the pan out. When I'm done, I just bend it back
01-28-2014, 11:11 AM | #3 |
thanks.
07-23-2014, 04:16 PM | #4 |
Thought I'd drop a note and say I was able to get the shift cable bracket off without bending back the bracket. Used a flex wrench and a T40 bit from craftsman.
07-29-2014, 09:24 AM | #5 |
Beer Drink'n Knuckle Dragger
get you some 1/2" drive and go put a cheater on it
GOD BLESS MY BROTHERS & SISTERS THAT SERVE WITH US - 67 GMC Long-Wide 350/SM420 My BACON Wrapped Meatloaf Recipe |
